12 Bolt
you get to pick which posi/locker you want (or a spool) and which gear ratio you want.
Well it looks like ill be checking into this then. Thanks guys
i probably have in the neighborhood of 310 hp at the wheels, i have a clutch that grabs slightly more than stock and has about 15-20 passes at the dragstrip on this car and the rear is starting to go, its making a lot of noise
i launched at the track on BFG KDW's so traction was limited even
im in the process of finding a 12 bolt for my car, im mainly going with the 12 bolt because i can retain my abs and i dont plan on beating it too hard at the track on slicks, for that i think the 12 bolt should suffice
