LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   I'm thinking of some springs (https://ls1tech.com/forums/lt1-lt4-modifications/756809-im-thinking-some-springs.html)
My94TransAm Jul 27, 2007 10:38 AM
I am looking at dropping my car with lowering springs. I am not sure what would be the best for me and price is a factor. I looked at Edlebrock, Summits, and Eibach. I dont want to drop the car more than the 1.3 in springs. But I looked at the 1.5in, and the price was right. I also dont want to change the shocks right now also because of price. I am wanting to put them on myself but I am scared to do the fronts because I dont have the tools to keep the shocks compressed. And I need to get an alignment done after I install them, right?
I was looking at these two:
http://store.summitracing.com/egnsea...=KeywordSearch
Also at this 1.5in drop:
dhdenney Jul 27, 2007 10:44 AM
Have you considered Sam Strano springs? BTW, I'd consider doing shocks at the same time cuz of the work involved.
My94TransAm Jul 27, 2007 10:54 AM
Nope, I have never heard of them but I will look into them. I dont want to put shocks b/c I am tight on money right now.
dhdenney Jul 27, 2007 11:16 AM
You'd come out ahead on labor and a little cash if you can wait and do them all at once. It's a lot of trouble in my opinion.
Stroked96Bowtie Jul 27, 2007 11:49 AM
Hes got a good point...Im waiting for extra cash to put springs on my car and will be doing shocks at the same time...Im sure alot of folks dont replace the shocks so Im sure it can be done but would save you time down the road.
FAD2BLK93 Jul 27, 2007 02:58 PM
Do not attempt to do this without the proper tools...you could be seriously hurt.
slowmofo Jul 27, 2007 03:27 PM
eibach prokit. I have LT's with no issues at all, just have to watch for the larger then normal speed bump and some driveways
White 96LT1 Jul 27, 2007 03:39 PM
get the hotchkis spring:) you will love them:) (i have long tubes with a catted y-pipe)
look at mine:
https://ls1tech.com/forums/appearance-detailing/756482-lowered-lt1-t.html
chavez885 Jul 27, 2007 04:07 PM
for the front all he needs to get springs off is the spring compressor tool...rent from autozone for 40 bucks...the hard part is breaking the spindle from the UCA joint.
seawolf06 Jul 28, 2007 01:41 PM
Don't even bother with new springs if you're not gonna get new shocks as well. The ride is going to be terrible.
nighthawk15 Jul 28, 2007 02:56 PM
Springs without shocks = very bad idea. Not only are you causing yourself a lot more work in the long run, but chances are your stock shocks will bottom out on some bumps. Lowering with improper shocks will wear out your shocks FAST as well, so be ready for the crappiest ride you've ever felt.
1bdbrd Jul 28, 2007 02:59 PM
I would get some QA1's if I were you. I just picked myself up a set of QA1 R Series front coilovers and rear F Series shocks for 550 shipped. Then all you need to do is come up with a solution for the rear springs and you are good to go with adjustable fronts, and adjustable shocks and struts.
seawolf06 Jul 28, 2007 07:15 PM
I've seen friends try to run QA1 springs on the street and what they've found is that they just don't last. They are a good quality spring if you don't drive much, but for a lot of driving, they just don't hold up.
You'd be better off doing the shocks first and then springs later. The Koni's will give you some drop (.5" or so) and then you can remove the rear spring isolators and use the rubber hose method to drop the rear some. You can also try using V6 springs in the rear if you want.
There are plenty of choices of springs. For the drop you want, look at BMR, SLP, Strano, DMS, and the Pro Kit. And yes, you will need an alignment as well as an adjustable panhard bar to adjust the rear end.
This helps me a lot:
http://www.angelfire.com/my/fastcar/suspension.html
94'BLKBRD Jul 28, 2007 07:17 PM
pro-kit f t w
1bdbrd Jul 28, 2007 07:22 PM
I know many people that use QA1s on their street cars around here and drive 10k+ miles a year on just their fbodies and they last. Honestly I've never heard of a local guy changing his QA1 springs.
seawolf06 Jul 28, 2007 07:26 PM
I know of one guy that blew out the front shocks. It could have been a bad set, but I just wanted to mention it.
LT1Falcon Jul 28, 2007 07:41 PM
y dont u just do it for free and cut a coil out of your stock springs? measure the distance between each coil when all the weight is on them and each coil u cut out will lower it that much. so if u want to lower it half the distance just cut out 180 degrees of coil. maybe this wont work on f bodies, but it is a common trick with older cars. it will also stiffen the ride a little if thats what u want. call it redneck, but many people do it
Hot94Z28 Jul 28, 2007 08:41 PM
Its a bitch to get the front spring off the shock. Trust me its better to get shocks the same time. Plus your probably going to have to buy new isolators for the top when you do it.
Mojave Jul 28, 2007 08:53 PM
Another vote for Strano springs and at least Bilsteins if not Konis. Definitely do both springs and shocks at the same time.
seawolf06 Jul 29, 2007 12:57 PM
I know a lot of older guys do this, but I've seen some pretty terrible results on the newer cars. I don't know if it's because of the springs or people just doing it wrong, but it can make for too low of a drop or a very bad ride, especially with the stock shocks which are crap.
© 2026 MH Sub I, LLC dba Internet Brands
