radiator question
Old 08-11-2007, 03:30 PM
Burning Rubber's Avatar
Default radiator question
there is a port near the top on the passenger side tank on my stock radiator. where is it supposed to go??
Old 08-11-2007, 03:49 PM
lethal93ta's Avatar
a little more info? theres a couple of ports on the sides of the tanks, one port is the return from the heads, theres 2 others female threaded ports on the sides as well for a trans cooler, if your car is an M6 it dont use those.
Old 08-11-2007, 04:25 PM
Internet Mechanic
BlackScreaminMachine's Avatar
The top most goes to the coolant over flow tank on the pass side, under the battery,
Old 08-11-2007, 05:30 PM
That's MISTER MODERATOR
Paul Bell's Avatar
The very top hose connection goes to the overflow tank. The next hose connection down goes to the return line from the rear of the heads.
Part 3: http://shbox.com/1/93-94_hoses.jpg
Old 08-11-2007, 05:51 PM
the connection i am talking about is the third one down on the passenger side tank. Its a female and kind of angled up a lil bit. its big enough to fit a 5/8 heater hose inside of it.
Old 08-11-2007, 06:04 PM
lethal93ta's Avatar
thats the low coolent sensor hole.
Old 08-11-2007, 06:45 PM
Paul Bell's Avatar
Yup!!
