throtle body
the throttle body by-pass??? all you do is by-pass the colant from going throught the bottom of the throttle body and connect the hoses together... not to hard but really not worth it...
i think it is worth the 2 dollars and 20 minutes. just the fact of knowing hot water is not heating your incoming air is worth the little time and money, even if it doesnt do much good
Originally Posted by camaro-94-z28
what to hoses do you connect together
run the "in" that goes to the TB right into the radiator , just look at it, your trying to Bypass the colant from going into the TB http://shbox.com/1/tb_bypass.jpg
