How much RWHP will a 2 bolt main LT1 handle
Old 09-05-2007, 04:03 PM
My2kz28's Avatar
Default How much RWHP will a 2 bolt main LT1 handle
Mods are in sig, But I have a 93 z28 with a rebuit lt1 (355). I have SRP forged dished slugs making 9:1 compression, forged Eagle H-Beams, STOCK lt1 crank with ARP bolts on the main caps as well as in the heads. Its a supercharged application, and on 11 psi I made 450 rwhp at 6000 ft (596 rwhp corrected)
How much power will my bottom end handle? Corrected #'s aren't as important to me, but in general, how much power is a 2 bolt lt1 capable of holding?
Old 09-05-2007, 07:11 PM
cruzin94's Avatar
probally more then that stock crank and if ur worried get splayed to a 4 bolt main and i hear there alot stronger then a factory 4 bolt like a vette engine
Old 09-05-2007, 07:19 PM
396D1SS's Avatar
I have seen alot more power run a long time without failure. As long as you dont rev to the moon you will be fine IMO
Old 09-05-2007, 07:27 PM
daniel6718's Avatar
well rwhp is hard to judge you could have from 10%-40% drivetrain loss
Old 09-05-2007, 09:10 PM
engineermike's Avatar
turbo355 over on turbomustangs.com has made over 700 rwhp and run 9's at 140+ mph with a stock 2-bolt bottom-end SBC and Badger pistons. Probably the exception not the rule though. . .
Old 09-05-2007, 09:22 PM
borninatransam's Avatar
its all about the amount of boost, the tune, and how hard you drive the thing. if you take it out and beat on it everyday of course the thing probably isnt going to hold up long, but if youre talking about it being a weekend warrior i wouldnt worry about it. like engineermike said 700 has been done and i wouldnt be worried to run 500-550 on a consistent basis.
Old 09-06-2007, 01:31 AM
In-Zane Moderator
ZONES89RS's Avatar
Id say you could go with 500 RWHP and get away with it with no problems, 550 even.
Old 09-06-2007, 03:55 PM
97ssmokem's Avatar
I had 605 RWHP on a 2 bolt and had no problems.
Old 09-06-2007, 05:46 PM
I bet the caps were walking around a bit. turbo355's didn't blow up, but the caps were fretted quite a bit underneath. At that point, the crank and mains probably won't last long.
Old 09-10-2007, 04:25 PM
My2kz28's Avatar
So if i ran 500 rwhp at 6000 feet above sea level, My bottom end would last?
Old 09-18-2007, 06:36 AM
dwhiteZ28's Avatar
ttt...Im going to be buying my f1a PROCHARGER today and I want to make sure that 500 rwhp will hold together. It will be tuned conservatively.
Old 09-18-2007, 07:44 AM
SS1156's Avatar
With a F1a I would definately go splayed caps. This way you can turn up the boost in the future. Hell I'm going to be splaying my caps with a 200 shot.
Old 09-18-2007, 09:18 AM
dhdenney's Avatar
You could probably make 800 horse on 2 bolt mains if you could do it in the lower RPM ranges. I'd say it's RPM that walks the caps, not the power. Any engineers or builders confirm? Also "shock" like sudden nitrous hits too. Just my opinion.
Old 09-18-2007, 10:44 AM
I imagine that the massive cylinder pressures required to make 800 rwhp at, say, 5000 rpm (1100+ ft-lb at peak torque) would cause some cap walk.
Old 09-18-2007, 06:07 PM
CNC Stew's Avatar
What he said. ^
Old 09-18-2007, 10:41 PM
My2kz28's Avatar
So if I splay the block for the 4 bolt mains, how much more rwhp will that support with ARP bolts, and stock lt1 crankshaft? What would it cost me to splay the block?
Old 09-18-2007, 11:19 PM
dhdenney's Avatar
Well hypothetically speaking of course with a N/A engine. I guess we'd be talking like 25-30 psi of boost. Yeah, I reckon that would walk the caps.
Old 09-19-2007, 01:19 AM
In-Zane Moderator
ZONES89RS's Avatar
Ok, there is a guy in car craft this month and has a 89 GTA with a old *** bone stock 76 350 with twins pushing over 700 RWHP, so that should say somthing.
Old 09-19-2007, 03:58 AM
Mike@ZMS's Avatar
I wouldnt expect a stock 2 bolt LT1 with any amount of miles on it to stay reliable much past 500. Its all about how it goes about making that much power though. If you rev the **** out of it, it will break sooner than if you were to boost it with a proper FI setup.
Old 09-19-2007, 05:58 AM
See post #5.
Quick Reply: How much RWHP will a 2 bolt main LT1 handle
