Wth??
Old Sep 22, 2007 | 06:52 PM
letsrun97z's Avatar
Default Wth??
this is plug 1 & 3 replaced map and maf still no luck it is pinnging/ really bad knock right at 3,500 at wot and still throwing code p0108 im lost it was running hella strong right b4 the spark plug change i dunno know what else to look for
Old Sep 22, 2007 | 06:56 PM
SincalT/A's Avatar
what kind of gap you got there?
Old Sep 22, 2007 | 06:57 PM
letsrun97z's Avatar
ngk tr55 .050
Old Sep 22, 2007 | 07:02 PM
Puck's Avatar
Originally Posted by letsrun97z
ngk tr55 .050
Drop your gap to .030-.035 and see how it likes it.
Old Sep 22, 2007 | 07:03 PM
SincalT/A's Avatar
well i have gapped mine at .035 with no problems.that was with about 11.3 to 1.I will reccomend .040 you got to remember that we have thee shittiest gas here too.btw the plug looks lean.
Old Sep 22, 2007 | 07:07 PM
letsrun97z's Avatar
damminit i use shell 91 all the time... i actually thought it is running rich i used 1/4 tank already and i have only driven it 35mi without going over 2,5k and when i did floor it both times smoke barrled out i dont know what color cuz it was at night i saw it in the rear view
would spark loss ie. broken wire cause all the cyl's run like crap or no?
Old Sep 22, 2007 | 07:08 PM
Revelation Z28's Avatar
yea its running hot and lean.
+1 on the .35 gap.
Old Sep 22, 2007 | 07:09 PM
SincalT/A's Avatar
ya pucks right .035 i just thought about it i was running comp 306 on that motor.that cam bleeds off alot more cylinder pressure than stock mabe if you had a hotter ignition system you could go with a bigger gap.
Old Sep 22, 2007 | 07:11 PM
letsrun97z's Avatar
damn i thought it would be good at .50 just beacsue the old ones were at .55-.60
Old Sep 22, 2007 | 07:12 PM
letsrun97z's Avatar
sincal are you in fresno?
SincalT/A's Avatar
you are blowing the spark out causing multiple cylinder missfire at the higher rpm's.
Old Sep 22, 2007 | 07:13 PM
letsrun97z's Avatar
im going to go take out #7 really quick
Old Sep 22, 2007 | 07:14 PM
SincalT/A's Avatar
manstinka
Old Sep 22, 2007 | 07:15 PM
letsrun97z's Avatar
wouldnt that show up on the scanner tho i used this http://buy1.snapon.com/products/diag...ewer.asp?id=97
and all it said was map sensor voltage low then it threw one for high replaced it and then the scanner said supect maf to be bad just baught a new maf earler no dice
Old Sep 22, 2007 | 07:24 PM
SincalT/A's Avatar
the map code i get somtimes because of low manifold vacum from the cam.Do you think it is possible there is an intake leak between the maf and the intake manifold causing low vacum and unread air to enter the intake.that will set a maf code also i believe?
Old Sep 22, 2007 | 07:44 PM
letsrun97z's Avatar
nope just checked put my old maf back on checked 1,3,5,7 plugs all look the same i dont get it.. i can cruz it up to 3,5 no problem its just when i hammer it, i just started it and ran my hand across the wires.. drivers side and i got zapped on #5 brand new wires i wouldnt think that would be the whole problem would it
Old Sep 22, 2007 | 07:52 PM
SincalT/A's Avatar
I also had a coil wire go bad and a similar problem occured.
Old Sep 22, 2007 | 08:05 PM
SincalT/A's Avatar
check it out this is also possible that your gap is so big that the spark would rather travel out the wire then jump across the electrode.this will also become more likely at higher rpm too.
Old Sep 22, 2007 | 08:14 PM
letsrun97z's Avatar
lol brand new wires and coil wire well i gess im going to speend some time and regap tm ****!!
Old Sep 22, 2007 | 08:18 PM
SincalT/A's Avatar
ya time for a beer to numb the pain you are about to endure!
