who has the cc306 or CC503 cam for the lt1
i have a cc503. it makes good power throughout the band and is street friendly. the cc306 will make more peak power but less hp/tq lower in the band and will want more revs than the cc503 to make power. listen to what people said in your other thread and go with a smaller cam or a custom grind rather than the cc306.
Man how many threads are you going to start about cams . Man just do a search there is alot of threads on these cams.
Here is some with a cc306:
https://ls1tech.com/forums/showthrea...ighlight=cc306
Here is some with cc503:
https://ls1tech.com/forums/showthrea...ighlight=cc503
For real. This has been discussed numerous times. It's a topic that's been beaten to death. The 305 will make basically the best street-friendly power of any off the shelf cam on stock heads.
If you want to sound cool with a high dyno number but run slow times unless you spin to the moon (bottom end won't like it) then get the 306.
And I couldn't find the dead horse smiley.
