wiring Q's
Old Oct 10, 2007 | 05:12 PM
TXFORMULA's Avatar
Default wiring Q's
ok,so i am just getting around to wiring up my e-waterpump. im wondering if im going to need a voltometer to find a 12volt source or is there another way? my chilton doesnt have voltage specs but i have found a few labels such as "ignition ctrl" & "ignition". will anything thats labeled "hot in run,test or start" or "hot in run or acc" work as the "keyed" source?
Old Oct 10, 2007 | 06:03 PM
infinitebird's Avatar
It's going to be kinda hard to any electrical work if you don't even have a volt/multimeter.
You can one for like $15-$20.
Old Oct 10, 2007 | 10:43 PM
Hark_Z's Avatar
Wired mine to the orange connector in the fuse box, I believe its like 10 volts, my buddy did a lot of the splicing and wiring so I really couldnt tell you more
Old Oct 10, 2007 | 10:46 PM
Speed Density's Avatar
hashtagBMW
Red = Constant 12v source
Pink = Switched 12v Source
Your underhood fuse box should be just fine to run a power, then just ground on the radiator support.
Tony.
Old Oct 11, 2007 | 02:04 AM
iceman15's Avatar
http://www.projecttransam.com/projects9.asp
Thants everything you need to know in there
Old Oct 11, 2007 | 10:51 AM
dhdenney's Avatar
I put a spade terminal on mine and just ran it to the switched side of a relay socket I didn't use anymore (ABS, AIR, etc).
