New to Lt1's Sup every one recently bought a 97 lt1 camaro and did a little test i went against 99 GTP and lost...? right now all i have is a K&N CAI and it came with flowmasters i recently replaced 4 leaky injectors as well has 156000 miles is there something wrong with my car or should i have won |
Originally Posted by slayer1234
(Post 7980633)
Originally Posted by erickeown
(Post 7980783)
dude, you should have stomped his ass if he was stock. You should have a ghigh 13 second car, stock he is low 15. Those cars arnt very impressive. Are u a4 or m6, have you did maintenance to your car (tune up). what kind of race did you have, give some details |
Originally Posted by SDfbody
(Post 7980795)
Was the GTP stock though? GTP's can be modded to run in the 13's fairly easy. He might have went up against one that was modded. Just something to think about... |
well he was stock it was a dead stop race i have an Automatic only thing i havent changed were the wires changed the plugs cahnged oil to royal purps de carbonized the engine and installed a CAI so whats up any ideas?? |
(Post 7980813)
true, ive seen one hit 13.9s with bolt ons, but he didnt say, im assuming he meant stock. I hope its modded cuz losing to a 15 sec car would suck. Btw, nice monte, have you ran the 1/4 yet. |
It came with a snyper body kit im not sure if its weighing it down by alot or what but i dont know how to post up pics |
(Post 7980825)
there was a misfire but it was because of the leaky injectors and it was running rich as hell i fixed that now and no service engine has come out. I dont know i guess ill keep looking into it thanks for the help |
get some gears, and a torque converter... then youre g2g :P |
I have less than 500.00 in mods on my 2000 regal gs, wich is the same drivetrain as the gtp. With 3.5 pulley, 3inch down pipe, stock PCM I went 14.09 at 99mph on a 2.2 60ft. Since then I have ported the exhaust manifolds(free 20hp) and gutted the stock airbox(20 more free hp). Then had a full tune done. So with perfect conditions I should see 13.6 at roughly 102mph. Point is gtp are cheap to mod and can run 13's easily. One of the best bang for the buck cars money can by, next to the LT-1. :) |
(Post 7980901)
That LT1 must be running pretty weak if it was a GTP stock. GTP's can run high 14's on a good day but c'mon, your car is not running what it should. First thoughts are tune-up and timing chain. |
Well I pulled the codes and there's nothing on it would the fuel octane make a great differnce I'm using mid grade but switching to premium I'm thinking about switching the opti to an msd not showing problems but I think its time to switch it being 156000 miles what spark plugs and wires are you all running I got the ngk tr55 oh and I couldn't find the free mods in search any one have a link? |
(Post 7981440)
ill try the seafoam out straight to the tank and ill see whats up.. would a service engine light come out if the o2s were bad?? |
you definitely should have seen him in your rearviews. maybe a clogged converter. does it run smoothly at idle? if not, check your ignition system. it could be also be fuel related, like a clogged fuel filter or faulty fuel pump. maybe the TPS is off and not reading as WOT or maybe the MAF is bad and not measuring properly. it could be a combustion problem too. try putting in some 8cyl Restore & valve/injector cleaner, or just get a compression test. have you been putting in less-than 92 octane in? have you noticed any pinging? loss of power could be just about ANYTHING until the symptoms are narrowed down... |
We still need to determine if the gtp was stock! I will give alot of LT-1 all they want from a roll to 100 in my regal gs with basic mods. |
Here are some stock gtp numbers, not 1999, but 1997 and 2000: 0-60 1/4 1997 Pontiac Grand Prix GTP 6.6 14.9 (Car Craft) 2000 Pontiac Grand Prix GTP 6.8 15.1 |
| All times are GMT -5. The time now is 12:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
