LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   AFR 227's what headers? (https://ls1tech.com/forums/lt1-lt4-modifications/803147-afr-227s-what-headers.html)
Formula934 Oct 23, 2007 08:26 AM
hey guys,
going with the AFR 227's, 396 setup and wondering what headers I need to go with. Ive been doing alot of research and its pointing towards the 1 3/4 to 1 7/8 stepped header. So I know kooks makes that header but is extremly expensive. Just wondering what you guys are running and if theres anything a little less pricey. please post your set up, part numbers, price and/or anything else that would be helpful. Thank you
stroked30th Oct 23, 2007 08:33 AM
Hedman has a set of 1 7/8 w/ a 3 1/2 collector. I like mine :devil:
Part no. 65387
Tony Shepherd Oct 23, 2007 08:52 AM
I am running the Hedman stepped header as well.
stroked30th Oct 23, 2007 08:59 AM
That part no. I posted is for the speard port full length 1 7/8 header.
Formula934 Oct 23, 2007 10:25 AM
Do they have a standard port 1 7/8's hedman header ?
stroked30th Oct 23, 2007 10:35 AM
Part no. 65385 looks like they are standard port. :confused:
The 65387's came with adapters and hardware to use on a standard port.
Formula934 Oct 23, 2007 10:40 AM
yea I was just looking at the 65385 headers and they do look like standard port, maybe ill get them a call... I havent ordered the heads yet so maybe ill consider going with the spread port.. Is there any advantage in going with spread port ??
OutlawZ Oct 23, 2007 04:11 PM
I run the standard port 1 3/4 stepped to 1 7/8" like tony's as well. Fitment is real nice.....
They are really good quality for the price...
stroked30th Oct 23, 2007 05:31 PM
I'm no genious, but I would say unless you're gonna spray it heavy or go FI standard port will be fine.
My AFR's had both standard port bolt holes and Stahl pattern bolt holes; not sure if all AFR's are that way?
Formula934 Oct 23, 2007 09:31 PM
ok so ill definately be looking into Hedman headers, thanks guys for all the help and hopefully ill have some dyno numbers by spring!!!
© 2026 MH Sub I, LLC dba Internet Brands
