LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   car won't start (https://ls1tech.com/forums/lt1-lt4-modifications/803254-car-wont-start.html)
TAdriver Oct 23, 2007 12:51 PM
car won't start
I have no power to anything. The engine won't turn over, no headlights, windows, guages, etc. I took my battery to Autozone and it checked out fine so I charged it last night and installed it this morning and still nothing. Does anyone have any ideas on what I should check to get my car running again?
SprayedZ Oct 23, 2007 12:55 PM
Check fuses, check all the wires, and make sure you have a good conection on the batt.
DarkKnightTA Oct 23, 2007 01:14 PM
Turn the key...Just kidding. I would check the wires to the battery, its something electrical, which sux, cause theres so much to check. But start witht he basics.
kinglt-1 Oct 23, 2007 01:32 PM
Check the fuseable link!
Formula350 Oct 23, 2007 01:35 PM
Which one of the many there are? ;)
I would check your grounds, or at minimum get new battery cables. Positive and negative ones.
TAdriver Oct 23, 2007 03:23 PM
The day I found out that it wouldn't start I was able to crank the engine but I let off before it cought and when I went to crank it again that is when I had no power anywhere.
JASON11WS6 Oct 23, 2007 03:27 PM
I'd check fuses and ground wires. Easiest solutions.
TAdriver Oct 23, 2007 04:16 PM
I got it running. Turns out that one of the nuts was loose on the positive junction.
Formula350 Oct 23, 2007 04:17 PM
That might be a fuse, but no power to ANYTHING would mean multiple fuses I believe. That's why I would say a positive or ground (negative) wire. I'm not sure if the power to the main fuse box (under the hood) is a fuseable link, but that maybe blown, as King suggested. Again, that's if the main line to the box is a fuseable link.
EDIT: heh You posted as I was typing. Glad to hear you got it running. I didn't feel like saying try and tighten the bolts, as to not come across like an ass, since that's the first place to always check :\
kinglt-1 Oct 23, 2007 05:23 PM
I would think you should of checked that before posting this thread.:D My suggestion of checking the fuseable link was based on you already covering the basics. Well anyways good to hear that you figured it out.
DarkKnightTA Oct 24, 2007 01:30 PM
So I was right turn the key on. HAHAHA. Just kidding. Glad to hear it was something simple
BizZzatch350 Oct 24, 2007 01:52 PM
Thats happened to me before many of times, usually if it hasn't been messed with or modified, then its some thing simple.
© 2026 MH Sub I, LLC dba Internet Brands
