weight vs power difference between CB to TD's is 2.5" true duals w/ a X pipe over the axle with sweet thunders worth the weight and power over a Hooker Aerochamber catback?? thanks so much... the car with done with be a 355 mild H/C |
its worth it in sound alone, but it does weigh more, but it also makes more power. sorry no numbers though |
My Magnaflow cat-back and pacesetter y weighed almost 50lbs on the nose. I switched to 2 Hooker straight-through mufflers with a 6" pipe between them and the header dumped under the floorboards, saved about 26 lbs total. I would imagine an x-pipe and 2 pipes over the axle would probably add about 10-15lbs easy over a single cat-back system. |
A dumped setup wouldn't be unbearable with a mild H/C car. It may be impossible due to inspection or something, but it would sound amazing while staying light. |
i went from 340rwhp on a y pipe setup, to 364rwhp with 3" true duals on my single cam setup. definetly go with true duals. the sound alone will convince you :) |
I love my duals but i'm ready for tailpipes. |
I loved my dumps, I never minded them but you do have to watch were you go WOT at |
maybe 3" duals custom done over the axle and out the back. I hope that standard aluminum will not weigh as much as SS. which most good CB's are anyway. |
Originally Posted by emerica4601
(Post 8040724)
i went from 340rwhp on a y pipe setup, to 364rwhp with 3" true duals on my single cam setup. definetly go with true duals. the sound alone will convince you :) as opposed to what? twin? :D |
Originally Posted by seadoo
(Post 8043888)
maybe 3" duals custom done over the axle and out the back. I hope that standard aluminum will not weigh as much as SS. which most good CB's are anyway. 2.5 dauls are like a mufflerX 4inch exhaust almost, they flow alot and are alot better than a Y pipe setup.. Trust me if you can go dauls! And I had good ground clearance with mind! I suggest going with a X pipe for velicity, im not a fan of the H |
i got heads and cam.. right now im running LT's ORY and borla (no plate) so straight basically.. will it be louder then that?? I kinda like my tips thats the only thing and cops like to notice them to considering my car is so loud.. haha i got a muffler bitch! But more power is always good |
(Post 8040724)
i went from 340rwhp on a y pipe setup, to 364rwhp with 3" true duals on my single cam setup. definetly go with true duals. the sound alone will convince you :) What kind of y-pipe setup were you running? What I mean is, what kind of catback were you using? |
I guess I will go custom 2.5 inch duals running in the same location as a catback and go over the axle. I may need a panhard rod relocation bracket because I am going to be running strano springs.
Originally Posted by slick1851
(Post 8044423)
You dont need 3inch dauls 2.5 dauls are like a mufflerX 4inch exhaust almost, they flow alot and are alot better than a Y pipe setup.. Trust me if you can go dauls! And I had good ground clearance with mind! I suggest going with a X pipe for velicity, im not a fan of the H |
i'll be running 3" dual system. I don't see the need to go from 3" collector and reduce the size especially since I'll be heavily modded in the future |
(Post 8043888)
Originally Posted by kgkern01
(Post 8047292)
Do you mean aluminum or aluminized pipes? If full aluminum could be used i'm sure it would be lighter with dual than a catback. Where can you get aluminum tubing? Why isn't it used more often?. |
Originally Posted by transamws6_97
(Post 8046384)
i'll be installing it in the next few months but i'm gonna start out dumped and if thats too loud for me then ill save up a lil extra and get it taken out the back |
the bad thing is I am going to be lowered on strano springs. |
| All times are GMT -5. The time now is 05:20 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
