Are the LT1 engines a 4 bolt main?
It's a two bolt unless someone swapped your engine to a 4 bolt vette motor at some point down the line, or you received a warranty replacement motor from GM itself at some point.
All f-bodies came with 2 bolt, regardless of year.
Only way to know for SURE is to pull your pan and look at your main caps. Both 2-bolt and 4-bolt blocks have the same casting number (10125327) and are stamped "327" on the side of the block.
I believe there were 106 SLP 1997 Camaro's that came with the LT4 engine.
