lt1 fuel problem ok, I have a 93 camaro that I changed over to a carb setup, I am using the cars pcm to run everything. proplem i am having is the fuel pump want stay running. it will run and prime but when you start the engine it want run? it does not have the opti, how do i get the "low-res" signal to reference the fuel pump?.....thanks mike |
there is a blue wire on the passenger side of the engine bay near the stock tower that you can use to manually turn the fuel pump on for testing purposes. What you could do is wire in a relay and apply 12volts to the wire and turn your pump on. |
Thanks for the help, i got it going this morning....mike |
© 2024 MH Sub I, LLC dba Internet Brands
