cam help!!
Old Nov 25, 2007 | 10:57 AM
mean94lt1's Avatar
Default cam help!!
i need help on the right cam to pick i have a 94 z
stock bottom end
heads are port matched exhaust is ported
intake is ported
36lb injestors
58mm tb
msd 6al
mad blaster coil
cc503 cam
1.6 roller rockers
comp hardened pushrods
aero fuel press reg
im planning on doing the bottom end this winter and am going with a 383 or 396...wanted some help on going with a cam i want to go big but i want to make the most power
Old Nov 25, 2007 | 11:23 AM
grn95t/a's Avatar
call comp and get a custom grind for your set up.
Old Nov 25, 2007 | 10:57 PM
kinglt-1's Avatar
^agreed! The difference in cost between custom and shelf cam is minimal anyways!
Old Nov 25, 2007 | 11:01 PM
xxtheonlyxx's Avatar
On comp cams website they have a cam selection tool. Download it, update the sheet with your mods, and it will give you an option of what cams will work best.
