Need help with fuel line mod
Old Dec 9, 2007 | 09:27 PM
Bad_tx_Z28's Avatar
Default Need help with fuel line mod
Hey there guys...well i have decided to do a bunch more to my car when its down for the header install. One of the things i wanted to do was the fuel line mod. im really wanting to clean up my engine bay. so...what all do i need and what is the best way to go about doing it...thanks alot!
Old Dec 9, 2007 | 09:55 PM
Ralls's Avatar
Like this?
Old Dec 10, 2007 | 07:01 AM
Bad_tx_Z28's Avatar
Originally Posted by Ralls
Like this?
yeah its pretty similar...what all did you do?
Old Dec 10, 2007 | 02:37 PM
Ralls's Avatar
https://ls1tech.com/forums/appearance-detailing/570128-lt1-guys-relocating-fuel-rail-lines.html
I bought the quick disconnect fittings from Pure Choice Motorsports. I believe it's 24inch lines. Bad thing was, for some reason the fittings for under that car would not go on the factory line. I had to literally use a dremel with sandpaper and grind the end of the line so the fitting would fit. Those fittings aren't cheap either.
