Power Braking from roll
Old Dec 17, 2007 | 11:44 AM
th3brandon's Avatar
Default Power Braking from roll
i would like to know what u guys think of powerbraking from roll being that iam an a4 and cant really down shift lol..... : coulnd i get a better start from a roll by doing this or is this just going to put a hurting on my car????????
Old Dec 17, 2007 | 11:49 AM
Bad_tx_Z28's Avatar
the only point for power braking is to heat up the tires befor a pass....doing it froma roll would put some serious stress on your rotors and possibly warp them...
Old Dec 17, 2007 | 03:43 PM
96lt1m6's Avatar
that mthod is called "brake boosting" the only way you will achieve this is if you had a turbo.we do this to help create boost while already rolling.
will not work on a Normally Aspirated car.
Old Dec 17, 2007 | 04:16 PM
th3brandon's Avatar
yea i herd of that on boosted car before just was not sure if it would help any with getting the rpms up high in the power band
Old Dec 17, 2007 | 04:53 PM
CamaroRacing12's Avatar
whynot downshift into 3rd or 2nd?
Old Dec 17, 2007 | 06:29 PM
LT1Falcon's Avatar
im not sayin u should do that, but y cant you down shift? you have a shifter right? just pull it back to 1. and are you trying to do this to heat your tires up or just for fun?
Old Dec 17, 2007 | 07:17 PM
TXFORMULA's Avatar
why dont you get a different torque converter if you dont like the stock a4. it should make it more fun and take off better
Old Dec 18, 2007 | 09:25 AM
The LT1 That Could's Avatar
manually downshift it. LT1s are torquey from a roll if you are in the right rpm range.
