I diddnt know headers F***** up Lt1's this much So its day 2 of my install of pacesetter headers and ORY, everything drives perfectly fine until the car warms fully up. Then it idles like a cammed car, and it bogs when trying to accelerate and surges power. I couldn't get it up to 50 under normal acceleration. There is no SES light coming on either. very hard to keep a constant speed with the sparatic power it idles real low like its about to stall out almost sounds like shit. rev it up in neutral and everything is fine. I dont think it could be the opti or plugs because it is only happening when warm and because there is no ses light then that leads me to believe that my O2's are fine? before all of this everything was fine, I dont understand what happened? |
Check your plug wires. I installed the same setup on my brother 95 z28 and the plug wires tend to touch the headers, causing them to melt and ground out. Car ran like absolute crap. My money says that the same thing happened to you. |
alright ill peek under there. Which wire was it for you? |
the one thats touching the header |
ha ok ok, I already caught one that was touching on the passenger side so hopefully there is another one so it will be a simple fix |
You should also make sure you didn't cut or pinch a wire. The O2's are wired in series with other sensors and if you pinched a ground reference wire for the PCM, then it could cause all sorts of odd behavior. |
Look around and make sure you don't have anything else to close to the headers and y-pipe. I wrapped my fuel lines with the heat reflective tape were the y-pipe was close. Also there might be some wire looms that could be pulled back and zip tied. Look around and make sure everything is good to go. |
just wait till its dark out start ur car and pop ur hood ull no pretty quick if u torched a wire |
Originally Posted by oifish
(Post 8414918)
because there is no ses light then that leads me to believe that my O2's are fine? |
Originally Posted by infinitebird
(Post 8415154)
The o2s in my car (also 94) were completely dead and I had no ses light. it can happen yup i had the same problem with mine a new set of O2 sensors did the trick and do yourself a favor and get some ACDelco's or some Delphi's they are cheaper than the crappy bosch sensors and work better (atleast in my car) |
Originally Posted by 1994Z28Lt1
(Post 8415246)
it also sounds like you could have torched a plug wire it can be tricky to run the wires in the stock location on the passenger side yup i had the same problem with mine a new set of O2 sensors did the trick and do yourself a favor and get some ACDelco's or some Delphi's they are cheaper than the crappy bosch sensors and work better (atleast in my car) agree happened to a freind he burned the o2 sensor wire going from the wiring harness. had stupid problems untill he fixed it |
If the car runs fine cold, its not wires or plugs. Check O2's. |
Yea 02's are my guess |
Ok I looked under there to the best of my ability and did not see any torched wires, but wouldnt that be giving me a problem even when the car is cold? also I have the same O2 sensors in there from before. when it gets dark out I will look for any burnt wires.. what should I look for since I have never done this before? also one mechanic told me that my car might be running lean, which I call bs because its on the stock tune, but who knows. |
so I just called autozone and they only sell the Bosch ones, the salesperson there said that there are 3 total sensors 2 before the cat and one after. I thought that there was only 2? I think im more confused than frustrated |
only 2 sensors on a 94. |
Don't the headers need to heat cycle before you can install the O2s? I've heard this alot with the coated headers. How does it even run with the O2s out of it when doing this cycle? -Rick |
thats what I thought, now the problem is I can only find Bosch ones around here and the only place that sells delco ones are a dealer and there like 88 bucks compared to 56 at other places are Bosch ones that bad or can I just save 60 bucks? |
Originally Posted by RickyMartinZ28
(Post 8415495)
(Post 8415387)
so I just called autozone and they only sell the Bosch ones, the salesperson there said that there are 3 total sensors 2 before the cat and one after. I thought that there was only 2? I think im more confused than frustrated And for the guy that mentioned if it runs fine cold it's not the plug wire, I have seen otherwise. A wire that was burnt through and only touched the header when the car was at speed. |
| All times are GMT -5. The time now is 03:33 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
