Best N/A sprakplugs Hey guys...well of course have a question. So what is the best n/a spark plug? Im going to be running headers and MSD cap & rotor and msd's 8.5 mm wires? let me know what you guys thing. thanks! |
NGK TR55 or TR5 regapped are usually a good choice. Once you have a plug in the right heat range though, a plug is a plug, don't buy into gimicks. |
Originally Posted by 96capricemgr
(Post 8426630)
I always liked the tr55 when I used the stock heads |
Originally Posted by IH8FORD
(Post 8426806)
x2 for the TR55 . |
Originally Posted by JonCR96Z
(Post 8428260)
Are your's TR55s? That might be part of your problem. You should run TR6 since you have really high cylinder pressure and you have nitrous. |
(Post 8428268)
You told me TR55 would be the best. I'm such a cock sucker. |
arent the tr6 colder to prevent pre-ignition of nitrous? I would think hotter is better as long as no pre ignition. |
Another TR55 user here...15,000 or so miles them so far...I run 11.2:1 compression and gap them at .035"...They are nice plugs at a good price... --Alan |
I've had good luck with Autolites |
well since i am stock headed with LT's etc... what should they be gapped at? |
Originally Posted by Bad_tx_Z28
(Post 8428454)
TR55 or Autolites. Had no problem with either and had equal performance. |
TR55's for me too. You would be fine at .50 like Bolo said, I personally gapped them mine.35 which would be fine too and they work great, my tuner said it takes less pressure off the opti if gapped at .35. |
To many issues with NGKs, We have not had any problems with Autolites ;) |
I'm currently running TR55's, but I think Denso's are still the best. |
im running TR55's and fouled a few out. so im going to replace them with a fresh set gapped at.040. |
im running AC Delco platinums used on LT4 motors direct from GM |
well okay....i just ordered my MSD cap and rotor kit, msd 8.5 MM wire set, and NGK TR55's. thanks for the input guys! |
I run autolites :) |
© 2024 MH Sub I, LLC dba Internet Brands
