Anyone make a manual rack for LT1's I bought a BMR Kmember that has the standard rack mounts. Is there anywhere that sells a manual rack that fits in the stock location? I know that Madman sells one for around $600, but I'm running out of budget for the shootout and need one a little cheaper.... |
thunder racing sells a pinto rack |
Get the Madman kit. |
Madman is only one I know of plus it's a very nice kit. |
Looks like Madman it is. Now I just need to order it and a set of lower A arms and I'll have all my parts... |
Fiero rack Get a manual rack from a mid 80's Fiero. If you have a tubular K-member you can make some simple bolt or weld-on brackets. It works just fine...I got my Fiero rack off eBay for $25. I've got tons of money in my car. But no sense to throw away several hundred if there is a reasonably simple solution. But then again, I build everything for my car :) FWIW, Ronald |
Dont you have to have a manual rack specific K member? I dont think anyone makes a manual rack that bolts in the place of a power rack....or am I behind the times? David |
Madman makes a kit that will work with either k member |
| All times are GMT -5. The time now is 07:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
