i f*cked up
i f*cked up
i was takin out my o2's and when i put them in first i zip tied the extra wires to the harness well when i was takin it off i had my razor blade knife and when i cut the zip tie i also cut one of the wires of the harness from the computer and so im a royally F*CKED any suggestions of what i can do..... the plug isnt that hard if i could find a brand new one it looks like u can put ti back togeather
yea so any ideas is there any way i can get a new connecter because i looked at the on thats on the sensor and i can pull the wires out and if i had a brand knew one i could make it work or any other ideas im so pissed off i did this ****
go to the dealer, or caspers electronics and order a new connector
http://www.casperselectronics.com/mm...Store_Code=CEI
You solder the 2 wires that were cut. It'll only be like 1/8" shorter than it originally was.
You're making this out to be harder than it is.
Example...
Wire: -------------
Cut Wire: ------/-------
Soldered Wire: -----=-----
Old Length vs New Length
