Camshaft swap - Oil pump drive question
Putting my 1994 Z28, LT1 back together after cam swap. Everything I read just says re-install the oil pump drive. Is there any procedure to line up the oil pump drive assembly with the slot in the oil pump. Would cranking the engine with breaker bar while pushing down on the drive automatically set the key in the oil pump slot ?
