Finally Got Pics Of Ovc Wires And Headers
I like the OVC plug wires. I have them on my car, but only on the drivers side. Whoever change the plug wires last, whether it be the guy I bought it from, or the guy he bought it from, only changed the drivers side and left the passenger side alone, for some reason. I don't know if I'm going to order the OVC kit or not, when I change plugs and wires. It's pretty expensive to do that. I can get some MSD 8.5 super conductor wires and NGK TR-55 plugs for cheaper than just the OVC kit.
Yeah I don't see why you'd need OTVC. I mean if you route your wires just like the stock ones and use the little metal shields, you shouldn't have a problem.
Question for you guys running bigger wires e.g. 8.5mm etc., how did you run the wires on the front passenger side? I couldn't get my Taylors to fit in the grooves so I just run stock size...
you could route the stock wires under the headers if you wanted to. you will just need a few zip ties. they were out of the way enough as to not get burned. i ran my stock wires like this until i put the OVC wires on.
