Nitrous guys come in!
Old Apr 12, 2008 | 05:39 PM
95Lwind05's Avatar
Default Nitrous guys come in!
Hey i've got a couple questions for all of you (i tried searching but couldnt find much). Where did you guys run your nitrous line from inside your car to under the hood. ie under the car, passenger side, drivers side, ??. And where did you all mount your nitrous solenoids? Pictures would be greatly appreciated!! thanks in advance!
Old Apr 12, 2008 | 05:54 PM
96lt1m6's Avatar
PASSENGER SIDE:
N2O line along side door sill rail under the carpet up to the kick panel through the rubber grommets up through the bottm of the PCM,bottle in spare tire compartment....
Depending on the style of N2O kit will determine where you can place the selonoids!
Old Apr 12, 2008 | 06:13 PM
95Lwind05's Avatar
ok, I have a NOS Snyper kit
Old Apr 12, 2008 | 08:27 PM
GreatWhiteZ28's Avatar
I ended up drillin a hole in the fire wall by the Blower motor box
Old Apr 12, 2008 | 08:29 PM
socal's Avatar
inside in the pass side under the carpet and through the grament under the ecm
Old Apr 13, 2008 | 02:37 PM
robsquikz28's Avatar
solenoids under the car behind the splash shield area and lines all under the car and nozzle in and under the intake tube.
Old Apr 16, 2008 | 12:09 AM
95Lwind05's Avatar
k thanks guys, anyone else have pics of there nitrous set ups?
Old Apr 16, 2008 | 01:02 AM
daniel6718's Avatar
search the nitrous section...
Old Apr 16, 2008 | 02:31 AM
Speed Density's Avatar
hashtagBMW
I ran my feed threw the firewall pcm gromet. Really good place to go from.
And my solenoids are here:
FUEL
NITROUS
Old Apr 16, 2008 | 02:45 AM
porksoda's Avatar
https://ls1tech.com/forums/showthrea...hlight=nitrous
Old Apr 16, 2008 | 06:54 AM
DarkKnightTA's Avatar
Go custom, find the best place and put it there, it gives your car a look like no other.
