LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Best drop in replacement valvespring's? (https://ls1tech.com/forums/lt1-lt4-modifications/90531-best-drop-replacement-valvesprings.html)
10secondZ Aug 1, 2003 03:21 PM
I need to know the best valvespring's that can handle .550" lift easily and have adaquite spring pressure for around 230ish duration..is there a good spring/retainer combo that will handle this without milling out the spring pocket's?..do comp 987 dual spring's fit the LT1 head's without machining the spring pocket?..Thank's,
Carter
Gangly Aug 2, 2003 02:34 AM
Re: Best drop in replacement valvespring's?
Comp Cams dual valve springs will easily handle that...CCA-987-16 or CCA-986-16. one of the two.
97WRAITH Aug 2, 2003 09:33 AM
I use the crane part number 10308-1. It's a dual spring kit comes with shim, retainers, locks.It's good for .600" lift.Got it from Summit for $148.
96-speed Aug 3, 2003 10:07 PM
I'm running the 977s with no issues - EVERYONE I talked to before the install said it wouldn't work w/o machining the seats - worked just fine for me :).
Ryan
97M6Formula Aug 6, 2003 02:47 PM
With no machining I dropped in the cmotorsports springs I cant remeber which kind but if you call them they will know what you are talking about. They were only 48.00 too and have held high rpms with my cam
96-speed Aug 10, 2003 11:49 AM
Keep in mind that there is much more to selecting valvepsrings that what the max lift spec is. The lobe profile will have a big impact on how much open/closed pressure you need.
Make sure you install them at the correct height so you know you are actually seeing the correct pressures!
Ryan
© 2026 MH Sub I, LLC dba Internet Brands
