LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Valve Spring Options For RR's Only (https://ls1tech.com/forums/lt1-lt4-modifications/916227-valve-spring-options-rrs-only.html)
95z28camaro May 6, 2008 10:20 PM
Nobody has replied yet on cz28 so figured i'd ask it here. My question is will the stock LS1 valve springs work on an LT1. I'm planning on going with a set of 1.7rr's and was wondering if they would work. I assume they would handle the valve lift but over on cz28 they were saying something about them not being able to handle the extra weight of the LT1 valves. So can someone please clarify this, and if they will work would i need to buy ls1 retainers or should every thing else work ok? Also if the LS1 springs wont work do you think LT4's will do? thanks
95z28camaro May 7, 2008 02:17 PM
Anybody know?
© 2026 MH Sub I, LLC dba Internet Brands
