Any info on the Best heads for a 292xfi cam?
well i found a 355 383 and 396 stroker kits... and all are $1,500... and my budget is around 3,000 give or take a few hundred... i at least dont have to buy springs and stuff like that b/c i already have new things in... if i was to get all of this and everything be forged... wound the 292xfi cam be alright or still not good... i just want the cam that will get me going the fastest lol...
and with what you said im probally getting the 396... Here are some things and info that come with the kit...
BRAND NEW ALL FORGED SMALL BLOCK CHEVY ROTATING ASSEMBLY
sbc stroker kit LT1 late model
LT1 LT4 or any internal balance 1 pc rear main
actual displacement 397 ci = lots of booty kickin
64cc head at 0 deck appx 11.4:1
only 1pc rear main only 4.040 bore only flat top avail
a kit built to your needs...
435338756000
NEW 4340 forged non twist crankshaft from EAGLE with a 3.875 stroke. We have run these cranks past 1200hp without failure , your choice of one piece or two piece rear seal crank, 350 mains
We are the largest eagle dealer on ebay, we are proud to sell these parts with tremendous confidence.
EAGLE 4340 h beam rods 6.00" length, crs6000b3d
ARP 7/16" 8740 Capscrew bolts standard ( 190,000psi) unless otherwise noted. Optional ARP 2000 ( 230,000psi) recommended for small block engines exceeding 700 HP and big block engines exceeding 850HP.
Silicon bronze for floating piston pins
Multi-stage heat treated.
Certified 4340 steel, vacuum degassed to remove impurities.
Each forging is X-rayed, sonic tested and magnafluxed to insure quality.
All surfaces are 100% machined.
Shot peened to stress relieve that metal.
Precision alignment sleeves positively located the rod cap, maintaining big end bore size and eliminating cap walk.
Sized and finished in USA
For pistons we are suppling JE Pro Series forged racing pistons,
Part # 181909 1.050 CH Flat TOP
· CNC machined domes with radiused valve reliefs provide optimum flame travel.
Premium 2618 Alloy
· Pin fitting and double spiro locks included.
· 990-2930-150 wall wrist pin ( 150 grams ) included.
· CNC Machined ring grooves accepts 1/16 1/16 3/16 rings
· Oil rail supports included with all pistons designed for use of rail supports
Also a set of the MAHLE file fit racing moly rings,
KING ALECULAR PRO racing rod and main bearings.
This kit will internally balance without any problems, IF YOU DO NOT HAVE ANYONE TO PERFORM THIS SERVICE FOR YOU WE CAN DO IT PRIOR TO SHIPPING. When we balance them, we balance them neutrally which means you get to use the std pulley/damper and a std neutral balanced flywheel/flexplate.
with a 9.00 deck this will be -.010 below deck, for lower compression ratio do not deck block to 9.00"
and sorry for asking so many questions... Just need some help from someone that has expirence with this motor
435338756000
Premium 2618 Alloy
You do not have the budget to do this right so don't even try.
Notice the 11.4 compression is with 64cc heads, LT1 aluminum heads are a LOT smaller and this is going to jack compression to close to 13:1
You seem to think displacement is key, another reason to STOP and not start this project at this time because you not only lack the funds but the knowledge and you will endup spending a lot and getting little for it.
yea i know... im getting heads from ai... im not doing this for awhile... if i ever decide to i have a friend that works on these motors for a living.. and knows alot about them... i will have him do the work if i ever decide to do this... i may or may not mod it... i might just leave it how it is... and buy a bike...
I have this cam, just got it installed, fired it up and the push rods fell out...
Im thinking that stock length push rods are a no go.. Dropped it off at my buddies shop, they have adjusted and re-adjusted the roller rockers 4 times and still the rods fall out.
It was suggested that he use a push rod lenth checker to determine what the correct length is, now that we know there is an issue.
Waiting to see how this thing runs..
Comp 985 springs, new locks and retainers, comp cams chromoly magnum 1.6ratio roller rockers on a set of ported and polished stock heads..
Bottom end is a forged 383ci that spun easily to 6500 on the last cc305 cam, though it seemed to run out of breath around 5k.
Time will tell whether this cam works well with what I got... I just wish I could drive it.
