single plane intake worth it on my setup?
Now onto big power with that block.... Big Rick who ran low 8's with his LT1 block said that the block took the power but every single pass they made that went faster than 8.1 knocked the bearings right out of the block... came from Wormboy himself's mouth..... So above and beyond all that block integrity doesn't seem to be too much of a problem... More of a bearing retention issue and possibly lifting the heads off the block. are your heads o-ringed????
Tony and I are racing towards the 9.08 nitrous record (although admittedly I have a bit of a lead right now since my solenoids are on the car and awaiting nothing but better weather to go out there and test) "removes knife from Tony's gut"
I as well after spraying this thing into the 8's am going to put some 8.5:1 pistons in it and hang a 94mm single off the front. I don't plan on changing anything else. BTW, who made your headers???? Cuz i'm going to be trying to get as many parts together while the car is currently running on nitrous before going to a turbo.... God tony we think alike huh???
Engine will be out by the end of the week, taken apart this weekend, crank fixed and re-balanced next week, and finally re-assembled the week after. So I am more than a month away from hitting the track again. you deserve the compliments man. You're only the third person AFAWK (we know) that has run in the 8's with an LT1..... at least the people that surf this site which is pretty much the biggest site on the net dedicated to late model f-bods...
Hopefully Shep and I become #4 and #5....
From what I hear about nitrous pro flow they set their tune ups on KILL... I'm thinking even with the 150 shot we should be able to dump in between 1.1 and 1.4 seconds..... Especially with the nitrous cam we are running. According to Lance we will be able to get back the power from the inefficiency of the cam OFF nitrous AND the additional power from the shot itself. NPF also jets for at the wheels power not flywheel. So a 150 is more like a 180 or so.... If the car goes sub 9.40 on the 150 shot I think we'll have 8's shortly thereafter...
I heard you don't even need to run a radiator with that stuff????? Imagine that's NOT on a streetcar... but you can basically size down the radiator to minimums.... Did you have to do something to your tank as well????? something about the metal so it won't eat thru it.....
Do you or tony have the wilsons elbow on your car? I just picked one up and was wondering if i should start looking for a new hood? i got the stock hood right now
I would say you will more than likely need a cowl or SS hood.
btw can you run E85 with regular braided lines? What about a A1000 pump? Also what about the injector o-rings....do they have to be siliconized?
Im rocking the wilson setup too:
I just run the injectors off the A1000, sumped tank, and -10 feed -6 return. For the nitrous system I have a dedicated stand-alone fuel system. It will never run out of fuel! LOL
I would get a 3-4" cowl just to be on the safe side. I can't get E98 down here but I can get E85.
I had a converted Supvic built back in the day that fit under a stock LT1 WS6hood. I never got to test fit it on my car but the person I sold it too did. Pictures still lurk around every now and then.
Another benefit that the Single plane intake offers not just the equal cylinder distribution but more air will actually see the piston, which in turn will equal more power.
When I talked to Wilson manifold not to long ago they told me the Supervic would be the best choice for my application if I was in the 7,000 rpm range. They told me to stick with my manifold choice at my rpm level of less than 6400.
I say go for the Single plane. Remember though not all Single plane intakes are created equal
