Ladies and Gentlemen, my nitrous is now.......
Old 07-06-2008, 06:52 AM
FASTFATBOY's Avatar
Default Ladies and Gentlemen, my nitrous is now.......
OPERATIONAL!!!!!!!!!!!!!!!!!!!!!!!!!
I FINALLY figured out why my Accel 375+ was not working.....DO NOT use the fan fuse in the underhood fuse box for a 12 volt "switched power". The ecm turns the fans OFF during start...THAT drove me nuts for a while.
I Flowed the fuel system, put some 116 octane in the cell.....went out and hit the button.....oh baby that big heavy turd MOVES on a 175 shot!!!!!!!!!!
Will go to the track soon.
David
Old 07-06-2008, 07:17 AM
LT14LIFE JT's Avatar
Oh yeah! 600+ hp is fun on the street. You're knocking on the 9s now! Nice job. Good luck at the track.
Old 07-06-2008, 08:32 AM
Z-RATED94's Avatar
I can't wait to hear your results. May the single digit be yours!!!!
Old 07-06-2008, 09:03 AM
LS1TECH Sponsor
NightTrain66's Avatar
It is definitely set up for nitrous so post up when you get back from the track.
Lloyd
Old 07-06-2008, 09:55 AM
TwoFast4Lv's Avatar
Very Nice man I can't wait to see the numbers!
Old 07-06-2008, 09:58 AM
ABA383's Avatar
Good luck with the 175 hit...Maybe pigs can fly!!! Hahahaha!!!
--Alan
Old 07-06-2008, 10:09 AM
TwoFast4Lv's Avatar
--Alan
A 175 shot was good for just over a second on mine when it was 3,700+
Old 07-06-2008, 10:42 AM
IllusionalTA's Avatar
Get er Done
Old 07-07-2008, 07:08 AM
FASTFATBOY's Avatar
--Alan
MAYBE!!!
I have lost 40lbs since the surgery, down to 300 even.
I dont think it will run the 1/4 with the 4.11 gear and 28 inch slick or drag radial. It sucks up gear QUICK!
Got two options, drop back on gear OR cut my fender openings and put some 295/65 drag radials on it.
Old 07-07-2008, 09:29 AM
jasonisdn's Avatar
fastfatboy good luck at the track. if you wanna drop some body weight (you not the car) pm me i'll help ya out for free. good luck at the track.
Old 07-07-2008, 09:33 AM
Moderator
BizZzatch350's Avatar
Good luck with the car, should roll out hard on the gas.
Old 07-07-2008, 09:44 AM
Captainofiron's Avatar
lulz
Old 07-07-2008, 11:29 AM
96lt1m6's Avatar
Originally Posted by FASTFATBOY
MAYBE!!!
I would not cut....
3.73s would be the way,possibly 3.55s since tq does not require a bunch of gear...good luck bro and congrads to your weight loss
Old 07-07-2008, 01:31 PM
Tapout911's Avatar
Good luck David. Finishing my nitrous install this week. Its all mounted and plumbed, just gotta finish the wiring. I am in the same boat you are. With my 27" tires and 4.11s I cross the 1/4 right at 6800. No way Im making it on the spray. Looks like Ill be 1/8th mile till I change a few things.
Old 07-07-2008, 01:34 PM
TravisA's Avatar
Nice! Now get some track times!
Quick Reply: Ladies and Gentlemen, my nitrous is now.......
