Low Oil Light Wont Go Away
Old 07-11-2008, 11:18 AM
SEXICAN's Avatar
Default Low Oil Light Wont Go Away
so i just rebuilt the motor and and its full of oil and has great oil pressure but my low oil ight comes and goes.Before i touched it it never had a problem and when i put it back together the oil level sensor did not look broken. any suggestions?
Old 07-11-2008, 01:14 PM
ctx97's Avatar
Replace the oil level sensor?
Old 07-11-2008, 02:04 PM
GLT1's Avatar
replace the oil sending switch on top of the oil filter.
Old 07-11-2008, 02:24 PM
96redcamaro's Avatar
Mine stays on too
Old 07-11-2008, 02:41 PM
the_merv's Avatar
Get rid of it..then take the Wire that goes from the Gauge Cluster and splice that in with the MIL Wire. That way if there is a reason for the MIL to come on, both of them will light up..otherwise it will be off.
Old 07-12-2008, 10:01 AM
SEXICAN's Avatar
i guess i'll just replace it thanks
Old 07-13-2008, 02:56 AM
blindxeyed's Avatar
Mine comes on every time I start the car when it's cold. If I turn the car of, then crank it up again, it'll go away. Replaced the switch in the oil pan as well, didn't help. So I just said screw it and took the bulb out of the cluster.
Quick Reply: Low Oil Light Wont Go Away
