Throttle bodies
The 93 has provisions for a TV cable and the base plate with the coolant and IAC circuits is different. I run a "93" BBK 58mm all I had to do far as converting it was swap the base plate, the TV provisions are not in the way of anything. I just used a stock bottom off a stock TB.
