Maybe I'm reading wrong, but that oil pressure doesn't look bad. If your rpm is truly 900 rpm you still have 17 to 19psi at idle which is fine. Rule of thumb is 10psi per 1000rpm. What is your pressure like at cruising speeds? And no bearings do not necessarily make noise when they fail. |
Originally Posted by LT1forever
(Post 9905913)
Eh dont worry, there are alot of other LT1 owners who have spun a bearing at one time or another. It just gave me an exscuse to get a 383!:D |
Originally Posted by MadMike 97 Z28
(Post 9893693)
and it went to about 15 but i didn't drive the car just let it idle in the garage. So what is your pressure at when cruising? |
what he is saying is that he just let it idle to get that picture... meaning his oil temp wasnt as high as it would be as if he had driven it, then let it idle ;) I had my car out tonight and I paid attention to my gauge. Even at 600 RPM hot I am holding just barely under the first mark. I am glad I changed that oil pump spring. |
Originally Posted by SS RRR
(Post 9908643)
I'm a bit confused here. You claim the lowest oil pressure you could get was between 17 and 19psi. That quarter hash mark on the oil pressure gauge is 20psi. So what is your pressure at when cruising?
Originally Posted by JoeliusZ28
(Post 9908696)
what he is saying is that he just let it idle to get that picture... meaning his oil temp wasnt as high as it would be as if he had driven it, then let it idle ;) |
© 2024 MH Sub I, LLC dba Internet Brands
