How to remove the haromonic balancer
One tip for you if for some reason you have to remove the entire balancer assembly....The "hub" portion of the balancer assembly DOES NOT have a keyway to locate it for re-installation. When I took mine off, I was lucky, as over time, the hot engine oil "tatooed" a mark in the crank snout. Be careful if you remove the hub, to make sure that you get it back in the same place, as it's important to do so.
