high rpm miss
Old Aug 29, 2008 | 11:33 PM
ElkySS's Avatar
Default high rpm miss
iv been throwing parts at this thing for a while now and i cant seem to get it right. it misses at WOT above 5500. new GM opti, MSD coil, Airtex fuel pump, ACdelco fuel filter, red top injectors, ACdelco regulator, GM icm, NGK TR-6s (had TR-55s, did it then too), it has a bad tune on it but i dont see how that could be it. iv been told my roller rockers need to be re-adjusted. it has LS7 lifters
Old Aug 30, 2008 | 11:19 AM
ElkySS's Avatar
no one? not even a "i had this problem once" story?
Old Aug 30, 2008 | 11:28 AM
Fixxer99TA's Avatar
It could be the tune, if its bad enough... Never know whats going on with that...
What have you checked in the order of cheap stuff (coil/icm - fuel pressure - plug wires, anything)? Even though its all new, something could be defective and giving you trouble. You mentioned someone said that your roller rockers needed to be adjusted, who told you that, do they know anything about cars? Do the rockers make excessive noise?
Since you have an AI cam, I assume you called them and they set you up with the proper springs? Your problem sounds almost like valve float but if AI set you up with springs it couldent be.
Old Aug 30, 2008 | 01:18 PM
jarretthise's Avatar
yea could be the tune for one....and is your bottom end stock??
Old Aug 30, 2008 | 01:43 PM
96FirebirdFormula's Avatar
i had something similar to that happening but didnt always happen, i ended up cleaning my tb and maf and the problem went away so its a possible item to check
Old Aug 30, 2008 | 07:20 PM
ElkySS's Avatar
the guy that told me that is an ase certified mechanic that scored perfect on his last ase test. i did adjust the rockers before the new lifters had broken in. you can hear them when idling but im told roller rockers make that noise
ElkySS's Avatar
and yes i bought the whole kit not just the cam
Old Sep 1, 2008 | 10:33 PM
ElkySS's Avatar
o yea stock bottom end. why? i replaced the icm, nothing changed, changed the coil, nothing, changed plugs and wires, nothing,
Old Sep 2, 2008 | 06:40 PM
Green3spd's Avatar
Man im havin the same problem but Im just a CAI and Catback car.... AND it doesnt happen all the time... opti/plugs/wires are about 5k miles...
Old Sep 2, 2008 | 07:05 PM
96capricemgr's Avatar
Walk us through how you adjusted the valves. This is somewhere a lot of guys make mistakes.
Old Sep 3, 2008 | 07:21 PM
ElkySS's Avatar
well, after setting each cylinder to TDC, i turned the nut until the pushrod had some resistance to turning, then tightened it a 1/4 turn, tightened the lock, then turned the whole thing about an 1/8-1/4 of a turn.
Old Sep 3, 2008 | 07:43 PM
"spin the pushrod" almost always results in too tight, often WAY too tight.
When the polylock touches that is zero, not even finger tight on the polylock, just touching and then try and move the pushrod inline between the rocker and lifter.
This is a VERY VERY common problem. I have no idea why this bad way of adjusting is so popular, it causes a lot of guys a lot of problems.
Old Sep 3, 2008 | 08:43 PM
BALLSS's Avatar
^^^^^^ ditto
Old Sep 3, 2008 | 09:00 PM
MYLILSS's Avatar
i tried that spin the pushrod thing and it didnt work for me.. i had to start the car and with it running, i wold tighten each poly lock by hand until it quit chattering then tighten the allen head afterwords, backing off a half a turn, then tightening the allen head and going another half turn to get back to where it quit making the ticking sound ... seemed to work for me
Old Sep 3, 2008 | 11:49 PM
blackz93's Avatar
Damn, you trying to strip the threads?!
And FTR, I have NEVER had a problem doing them this way. Mine are currently set at 1/8 past zero lash + a little bump of the polylock. Engine has been running for 3-4 months now and haven't had to re-adjust anything.
Old Sep 4, 2008 | 05:10 AM
The problem with this method is "slight resistance to spinning" is a lot harder to notice than it needs to be. Once the polylock bumps the rocker that is zero, MUCH easier to find that way.
Old Sep 7, 2008 | 10:17 PM
ElkySS's Avatar
well i went out and readjusted my rockers. this time with the car running i loosened and tightened on cylinder at a time. with it running i tightened it until it stopped tapping, shut the car off and tightened it 1/2 a turn total. i did all 8 cylinders and took it for a ride. nothing changed. i did notice that after a couple hundred rpms it does seem to go away. but i dont want to push it much higher than that. i wouldnt think a tune would cause this but then again i dont know anything about tuning. ill call HPE tomorrow and ask them. this may sound stupid but is it possible to over power the stock rev limiter?
Old Sep 8, 2008 | 12:23 AM
sounds like a valve problem to me....and on a stock bottom end you shouldnt be running it much past 5500 anyways...it will take out your bottom end...was this running for the dyno or something
Old Sep 8, 2008 | 05:33 PM
I have never bothered with running adjustment. Did you have asecond person turning the car off or did you have to let go of the wrench to turn it off?
Tuning issues can cause a whole lot of troubles.
Stock bottomend is fine beyond 5500, most of us find 6500rpm to be a more realistic limit.
If you have datamaster shoot me a PM and I will give you my email addy so I can look at a log.
Old Sep 8, 2008 | 07:09 PM
ElkySS's Avatar
no i dont have a datamaster but i think i found my problem. i hooked up a fuel pressure tester and took it for a spin. it held a constant 40 psi until about the time it starts missing. at one point it dropped to 30 psi. so i guess im gonna go ahead and get a granetalli fuel pump.
