Goodbye Opti! LT1 runs w/ coil packs and LS1 PCM.
#44
#45
Another good thing about the LS1 PCM (99-up) is that it utilizes the provisions to program a 4L80E using the pcm. Us LT1 guys have to buy a $700 TCI control box to function our electronic 4L80E.
I have a Delteq setup using the coilpacks from the GM northstar (standard Delteq coil packs) I figured it would be easier to setup an LS1 pcm on a setup like mine??
#51
Here's a question, for those of us that are OBD1 and don't have the crank sensor ready timing cover and already have a double roller timing set, and really dont want to revert back to a single row timing set, would it be possible to make a MSD crank trigger setup give the same reading as a crank sensor? I'm sure it'd have to be modified somehow but I'd rather use a modded version than change the aforementioned items. Sorry for the initial run-on sentence, lol! Would there be another way to get the signal?
#52
But since you're lazy and don't want to read
MSD:
LSx (36-1 I believe):
So, unless I missed something in all my own readings; No you can't.
Just fab something to bolt the trigger to the outside of your timing cover, like on the front of the dampener and then fab a brackets to reach out and pick it up.
#54
Wiring would be the easy part heh, so would fabing anything that needs to be fabbed. Tuning would be the trickier part for me and would have to be sent to someone who already did one :\
#55
OWN3D BY MY PROF!
He said he had this idea last year. Before I even told him how to do it he explained the whole thing to me. He said he was going to do it with a customers car, but he didn't want to have something overly complex that people wouldn't understand. We're probably going to do it on my 93. I'm going to a junkyard tomorrow and I need to get some random opti / water pump parts any ways so it shouldn't be too much extra work to get a 95+ timing cover.
We'll use a stock LS1 reluctor wheel and make a plate adapter to bolt onto the crank snout. Mount the crank sensor and change the injector and ignition wires for the different firing order. After talking to him it shouldn't be that hard at all.
#56
Why would you need a vented opti, when you're ditching the opti? Wouldn't even need the timing cover unless you wanted to have it more integrated. You can easily fab a reluctor wheel and bolt it to the hub and fab a bracket for the sensor. That's what Brian Esser did when he used the Ford EDIS system on his LT1.
(Huge write up on the Ford EDIS http://projectlt10.com/edis.html)
Now about this system...
I didn't read the article. But, whats so special about this? There have already been EDIS units converted to running Coil on Plug. Though they used aftermarket ECM's. A MS ECM +EDIS8 setup would still be better for the manual guys and way more tunable. If it's the argument of sequential vs batch fire, unless you are using sequential for emissions or idle quality there is nothing to be gained once you climb up the tach.
This seems like an option for A4 guys only.
#57
Yea, I know it's your site I book marked it for all that info, since I'd like to do that some day.
I guess the question is how much would an aftermarket setup cost, vs this conversion. Then that'll be the main answer for people running it. What's special though, isn't really a Q I can answer heh
#58
OWN3D BY MY PROF!
I could see the main benefit being cost and easability of tuning. With the mast majority of shops out there doing LSx tuning they'd already have the software and be familiar with it. I don't know of any shops around here that tune MS, but I know 3 that use EFI Live and 2 with HP Tuners.
#59
Well I was getting ready to get a tune on mine and asking my mechanic some questions , he told me I would benifit from a tune but theres only so much you can do to an LT1 PCM . I told him about this thread , he said he had read about it and that it was a KA idea quote " ls1 pcm are way better and faster , an 01 ls1 pcm is better than a 99 ls1 pcm etc " the newer the better said the mech . I'm going to wait and save my money for this set up even though I have all stock internals and full bolt-ons with A4 . Future le2 h/c , 3600 Yank stall , and I'm waiting on the Holley HSR intake from GGPC .
#60
SO FAR, I'm seeing.....
PRO's :
- !opti, hello coil per cylinder
- works with 4L80E
- Tuning (better existing software and alot more places that will help you with tuning)
- 8000 RPM rev limit
CON's :
- Doing it.... wiring, sensor adaptation, fitments
- Initial tune (who's gonna get an initial LT1 tune setup on the LS pcm)
- Price (dont really know about this but, what would it cost from start to finish?)
Am I missing anything? What, if anything, would you LOSE by going with an LS pcm swap??? Also, doesn't LS PCM take sensor readings differently (faster)? I would kind of wonder if you would get better performance, drivability, and even better gas milage from such a difference???? Not talking night and day differences but, still a step up. Hell, just the ability to be tuned and monitored with software that has more abundant support would sell a "KIT" like this to me. I've spent quite a bit to go with Delteq, LT1edit, and AutoTap over the years... Doubt I'm the only one.
PRO's :
- works with 4L80E
CON's :
