Goodbye Opti! LT1 runs w/ coil packs and LS1 PCM.
#61
I think you pretty much nailed it, hyper. As far as it reading sensors faster, no idea. Don't see how that would make any difference. A sensor, to my knowledge, is just putting out continual information. How the PCM reads it is up to the designers. Again, this is just an educated guess.
#62
^^ I was mainly wondering if the LS PCM can interpret the sensor data faster. If so, I would wonder if it would monitor and adjust the fueling and timing faster than the stock LT1 PCM... getting more accurate adjustments would keep you closer to peak efficiency in closed loop, no? Maybe it's just some wishful thinking... I dont know.
#65
I don't honestly know about gauges, but I think so for the PCM equipped cars. I can't see any reason why they'd go through the trouble and expenses of making new gauge clusters.
#69
Here's an update on this project.
We have a prototype CNC reluctor, but discovered (due to the double roller clearance) that the LT1 timing cover comes in contact with the reluctor.
An LT1, double roller chain, and any crank reluctor (96-97 LT1 4x reluctor or EFI Connection's 24x reluctor) is impossible. Here is why...
The back side of the pictured drawing just clears the double roller timing chain. To clear the LT1 timing cover we would have to remove more material from the front of the reluctor. As-is, there is only 0.040" to work with. There is not enough material available to take away to clear the LT1 timing cover. We have modified our design and will make another reluctor to test with on the LT1.
We will be building conversion harnesses for LT1 equipped cars to use the LS1 PCM.
To keep up with the latest progress, please email me at mike@eficonnection.com and you'll be added to the mailing list.
#70
SWEET!
So, a single roller will fit just fine though? I don't see why that's such a bad thing. Sure, it's not as strong, but it makes it possible!
Thanks for the update
#71
cool. Still watching this thing. Are you going to be making these on a mass scale or only when ordered? What kind of price tag is something like this going to have?
#72
#73
That just gave me an idea too, which I'll PM you S10. It's this: Since the Opti won't be there, and there's not enough room with a dual-roller for the wheel... Why not make it so the wheel mounts where the Opti WAS?
#76
A single roller will fit just fine.
Pricing all depends on the pieces you need. There are a lot of DIYers out there who may find the price of a "kit" unattractive. We expect to keep inventory of the 24x reluctors and crank sensors. We're going to try to keep up with the harnesses, but for the most part harness work will have a short lead time.
It's a big job to rework the original LT1 engine harness. We're going to leave that to the DIYers.
You're right; this will not be a $50 part.
We're mounting the cam sensor components there. It requires a new housing (to replace the optispark) that holds the cam sensor and gets a signal from a custom target mounted on the cam sprocket. Pictures and additional details will be available when this is ready.
Originally Posted by Formula350
I'd figure the harness wouldn't be all that special vs a standard LT1s. You'd just have to remove and maybe switch a few things to make it compatible.
The (24x) wheel I'd figure simply due to R&D costs and then machining time.
#77
S10Wildside : You mentioned people possibly not liking the kit price so pricing depends on what parts you need. Do you INTEND to provide a "complete kit"? Or, are you just saying its not cost effective and it'd be easier/cheaper for everybody if you only fab-up and provide the neccessary CUSTOM pieces leaving us a simple parts list to go gather up?
#78
#80
Thank you Mike at EFI connection (mike@eficonnection.com) for the e-mail of all the progress on this. I would highly recommend anyone interested in this get on the mailing list and read through their progress. It really cleared up all my questions of parts that will be changed and how its going. Obviously, a price is not really mentioned but cant blame them.... Hard to put a price on something thats still being developed.
One thing I didn't notice being mentioned was getting an initial tune for the LT1 motor on the LS PCM. Curious, Is that a big deal to generate or a couple simple tweaks to the typical LS programming? I would think that offering baseline (safe) tunes for your GEN I and GEN II (LT1) would be easy and benificial since your obviously already going to have a tune for your own prototype engine(s) for testing.
