How do I fix code p0441-- Evaporative Emission Control System Incorrect Purge Flow I have this code p0441, incorrect purge flow. How do I attack the problem? What's wrong, etc. Oh and I did a search, but nothing concrete. |
Most common is a stuck open purge solenoid. Should be normally closed. If theres little black bits in the line then your canister is breaking up and causing the purge solenoid to get jammed open. Then you need to fix that too or it will keep happening. |
Or someone decided to flip the lines around lol Naw, I doubt it's that, but that's what popped into my head when I read the "Incorrect purge flow" :P :jest: and now a "Spaceballs" quote comes to mind: "She's gone from suck, to blow!" |
I had the same code. I replaced the EVAP solenoid on the passenger side of the intake manifold, and the EVAP valve at the canister behind the rear driver wheel tucked under/behind the wheel well. Problem solved. |
check the gas cap.... some times you get lucky. |
thanks for the advice guys, and it wasn't the gas cap. |
Originally Posted by Formula350
(Post 10098450)
Or someone decided to flip the lines around lol Naw, I doubt it's that, but that's what popped into my head when I read the "Incorrect purge flow" :P |
Originally Posted by HoLLo
(Post 10098910)
It's hard to explain what it looked like, i couldn't really see it, but you just gotta feel up behind the wheel well with a flashlight. |
(Post 10299926)
I have the same code as of right now. My canister is comeing apart and put the bits in the solenoid. I talked to pcmforless and they said they can delete it off my pcm and still make it pass plug in emissions (not that it matters to me at the moment) |
I wonder if a bad cat cpould contribute to this- both of mine were recently replaced and then I got the P0441 abpout 70 miles later. Guess I'm not meant to have this car legal and inspected. Is there a map that could be purchased and loaded that would just tell NY state that the car is happy so you can pass? |
if you had both selonoids replaced and it happened again the answer to your problem is the source......replace the charcoal cannister! you may not have to replace the selonoids again just try to empty the pellets from them and reinstal.... |
Originally Posted by 96lt1m6
(Post 10306757)
if you had both selonoids replaced and it happened again the answer to your problem is the source......replace the charcoal cannister! you may not have to replace the selonoids again just try to empty the pellets from them and reinstal.... After looking in the service manuals I have, you have to raise the rear, take the rear driver's side wheel off and then you have access to the other purge valve. |
http://www.trademotion.com/schematics/F/FC93435.gif 9)Purge Valve???? 6)Solenoid????? Is that how they look like? |
anybody? |
I haven't read through this thread thoroughly but have you tried shoebox's site: http://shbox.com/1/component_location_views.html Are you looking at anything in this pic: http://shbox.com/1/evap_sol.jpg |
Originally Posted by integraxtc
(Post 10328967)
http://www.trademotion.com/schematics/F/FC93435.gif 9)Purge Valve???? 6)Solenoid????? Is that how they look like? FYI - You had them reversed in your diagram (I believe?) |
(Post 10328967)
http://www.trademotion.com/schematics/F/FC93435.gif 9)Purge Valve???? 6)Solenoid????? Is that how they look like? FYI - You had them reversed in your diagram (I believe?). |
Originally Posted by Evaporate
(Post 10343121)
I haven't read through this thread thoroughly but have you tried shoebox's site: http://shbox.com/1/component_location_views.html Are you looking at anything in this pic: http://shbox.com/1/evap_sol.jpg The other one is in the wheelwell, driver's side rear. You have to jack the car up, remove the wheel and fender liner to get to it. I left mine alone, as I can't find anything under P0441 that relates to the rear one. Maybe I'll mess with it over the winter when it's in the garage and I'm bored. |
© 2024 MH Sub I, LLC dba Internet Brands
