The Fastest LT1's on LS1TECH.com
Old Oct 23, 2008 | 06:07 PM
  #61
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Another update, just squeaked into the tens with her.
Jon Beam(silver 95) 10.994 @ 121.49, '95 Formula, stock engine w/Procharger, 3460 race weight
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Oct 24, 2008 | 07:36 AM
  #62
1SlowFormula's Avatar
all updated...
Old Oct 30, 2008 | 05:04 AM
  #63
LS1TECH Sponsor
Another update. Car just keeps getting quicker. I cheated, pulled the passenger seat and took some fuel out.
Jon Beam(silver95)-10.914@121.90, '95 Formula, stock engine w/Procharger, 3400 race weight
__________________
Old Oct 30, 2008 | 09:19 AM
  #64
blackz6sp's Avatar
Originally Posted by 1SlowFormula
Special thanks to JUICED96Z for compiling all this info to get the original list, now lets all contribute to keep it updated, post your times and updates in the format below...
NOTE: PLEASE PUT IN THIS TYPE OF FORMAT AND KEEP IT SIMPLE!:
Shon Herron-11.805@113.96, 97 Z28 M6, Bolt-ons/NA/3100lbs "Bolt on Record"
THE LIST:
"Big Rick" Intrau-8.08@176, 96 T/A, Lots of stuff, single turbo
Chris Sikora “Z8’s”-8.928 @152.61, 383 LT1, GM LT4 Heads/Intake, Vortech YSi
Joey Kenville 9.04@150, 97 camaro, th400, 396 speedtech plate, 3100lbs.
Jeff Gilbert (SSANDTA)-9.06@151.48, 96 TA 398, D1, A3, LT1 intake, AI TFS LT1 heads , OBD1 PCM, 100 shot, 3562lbs
Spray-9.08@159.7mph, 95 Z28 383 LT1, TH-400, N20
Dave DiLuca "SLED28"-9.11@155, 396 LT1, AFR's, TNT Fogger, 3415lbs
Madman-9.18@154,96 Firebird, 380ci LT1 with GTP AFR 215s
Taner-9.27@151.20,96 SS 399ci Harshaw Racing Engine,
Full BMR suspension. Quickest and Fastest M6 F body / First LT1 6spd f-Body in the 9's.
Jason Warren-9.3@142, 95 Z/28, 355 LT1, TH-400, LT4 TrickFlows, LT4 intake, stock crank, stock pcm w/recalibration, solid roller, 300shot, 3578lbs.
Mike Harvey(strokedz)-9.46@141, 95 camaro, 383 LT1 Ai 215 trick flow heads, Ai SR cam, Ai converted single plane intake, th350, 12 bolt, 433's, 3500# race weight. 250hp nitrous
Andrey Sokolov-9.48@144 94 Z28 A3 383, YSI, 190 AFR's, 9"
Jason Brisson(OutlawZ) 9.54@130.21, 95 Z28 A3, CSM Race Engines 383 AFR 227's, SR cam, Single plane, TH400, 9", 3.89's, 3400 race weight, NPF single stage plate n2o
Tony Shepherd 9.56 @ 143.68, 93 Z28 , 397 LT1, AFR 227, 3450lbs, 250shot
Eric Rheault (Row) 9.77@137 385ci,AI200 haeds and intake,th400,9" and 250 shot 3700#'s
T/ALT1-9.83@136mph, 95 T/A, 355 LT1, 10.5.1, CC306, LE Trickflows, LT4 intake, stock injectors, 3800 PI converter, TH350, 8.8" rear, 3.55's, 175 shot, 3,450lbs
Ed Wright-9.91@136.51, 96TA 4L60E, 383" LT4 heads & intake/NA/3250lbs
Mike V. (engineermike)-9.92@146.0, 95 Z28 A3, T76GTS turbo/3750lbs
Rick Abare-9.97@138.749, 94 TA 383 A4, AI 200CC heads/SR Cam, 3470#s, LT1 non welded intake
Dave Norquest "N20Dave" 9.98 @ 137 1.47 60' naturally aspirated, manual trans 396 SB2.2headed LT1 SR 28x10.5W's 3730lb raceweight.
Glenn Waguespack-9.98@128, 65 vette, 383 eagle light weight bottom end, home ported LT1 heads, Solid Bullet roller cam, Ported LT1 Intake
TwoFast4Lv-10.05@135, A4, DOI200, LT1 3,650lbs
383racecar-10.13@135.91, 95 Camaro,A3,383 le2 heads BRE cam,nitrous,3650lbs
Jeremy McKinney (VTEC) 10.14@131 350ci,stock shortblock,nearly stock heads,th400,9" and 150 shot 3050#'s
Z28&WS6-10.19@128.9, 94 Z28 383 T-400 D1SC 10-bolt 3.73
Glenn Coates-10.27@132, 95 Z28 M6, 383 LT1, Canfield heads, solid roller, 200 NX shot.
95 Formula-10.39@131.6, 95 Formula M6 355, stock crank, eagle rods, ross pistons. 12.5 cr, Ported GM LT4 heads, ported/welded lt4 intake, Cam motion solid roller, 25x/26x@50, 3300 ish race weight.
Jason Spasoff (lt1camaroman93)-93 Z28 10.41@131, 383 LE LT4 Heads, Custom SR cam, TH350, stock 3.23, 100-250 shot, 3200lbs
Mike Norkavage-10.41@131.58, 95 Z28, 383, AFRs, 200 shot, 10 bolt
97blkz-10.47@128 396ci LT1, GM LT4 Heads/Intake, 3200 vig, 3.73's, MT Slicks, 150 shot, 3500lbs
Charles Obstfelder "Chased"-10.48@131, 355 RGR heads/cam 200 shot, 4$60, 12 bolt, 3770 race weight
ray@nitrous outlet-10.481@129.91, 94 Formula, 700r4, 396/150shot,GTP stage 2 LT1 heads, 246/254 .613/.590 112lsa, 3200 stall, 3.73's 3450lbs
Bunny Mabile-10.56@124, Late 80's Firebird, LT1, mild ported heads, Hyd Bullet roller 230@.050, 3200Lbs, 750 holley
Josh H. "Ponyhntr"-10.570@135.01, 96 Z28 M6, 383, AFR, ProCharger F1A
WannabeSS-10.57@133 1.65 60', 96 SS M6, LE h/c, golen 383, spray
C Man -10.59@133.53 w/ 1.52 60', 95 Z28 A4, 383/Nitrous/3740lbs
Dave Jones-10.62@127 96 Z28 383, N/A, 3450lbs
LT1nitrouZ-10.63@128.9 94 Z 383, CC306, 10 bolt, 175 shot
Mike Comp T/A-#57-10.89@128, stock LT1 bottom end/cam, LT4 heads, 3000 stall, 3800lbs
Jon Beam(silver95)-10.994@121.49, '95 Formula, stock engine w/Procharger, 3460 race weight
Kryckter-11.0@128mph, 97 TA, 355 LE1.5, 200 sho,t 3600lbs, 3300ft DA
Paul Irvin(tapout911)-11.01@120 95Z, Solid roller 383, ported stock heads N/A.
FASTFATBOY-11.02@124, Solid roller 383, rhs heads, single plane, 4L60E, 9 inch 4.11's, 3800lbs
Ken Anderson-11.02@122, 95 Z28 A2, 355/Cam/Heads/NA/3350lbs
Z-Rated94-11.08 @ 121.93, LE heads, 222/226 Joe O. cam, 125shot.
Mr_Bond-11.10@123.15, 93 Z28, 230/236 Cam, PI 3000 Stall, TNT 150 Shot, Bolt-ons, 3.73s, 3665lbs
Chris Jones-11.12@127.61, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/150 shot/3220lbs
-PEPE--11.123@124.5, 97SS M6, LME Callies Solid Roller 396, 500 N/A rwhp.
Warren Dempsey (The Engineer) 11.132 @120.64, 1997 Z28 A4, Golen 396 short-block w/ AFR-195s, XFI-292, Kooks headers, 12-Bolt spool/4.30s, 3440 race weight N/A.
Frank95z-11.15 119.86 95Z28 Bolt-ons/3325/Cam only
Vaders94-11.174@123.91, 94 Z28, 355 LT1 11.1, JOE'O cam/LE2 heads, TH-350/3500 stall, 3.42's, 100 shot, 3,500lbs
Dean Stewart-11.18@120.83 N/A, 94 Z28, 11.6 CR 383, LE3 LT4 heads, BRE 230@.050 HYD, LT4 intake, 58mm AS&M, TH400 2800 stall, 3.73, 3550lbs
Brady Matysek (roadtrip120) - 11.224@126.3, 94 Z28 M6, 383 LT4, Dart CNC Pro 1, Solid roller, 3400 lbs
ABA383-11.23@121.18, 95 Formula 383 A4, LT1 ported heads, Joe O baby cam, Vig 3600, 12 bolt, 3.73s, suspension stuff...3600ish lbs raceweight
Matt94z-11.28@118.21, 94 Z28 TH350, 355/ MTI Heads/Joe O cam
TravisA-11.28@118.1, '94 Z28 A4/.060 LT1/AI 200cc H/C and Intake/3.73/N/A
Jason Short-11.37@126, 93 Formula M6, NA, 396ci, solid roller, AFRs, stock 10 bolt w/3.73s
jakesz28 - 11.303 @ 119.35 , 94 z28 , cam only 150 shot
daniel6718-11.3@118, 94 Z28, cc306, 3200 stall, 3.73, 100 shot
Sweetred95ta-11.33@118 w/1.53 60ft. LT4 Hotcam kit, bowl blended stock castings, 2.0/1.56 valves, K&N CAI, 3.42's, 3600 Vig nitrous converter, stock suspension, 100 shot NX kit, cut out, mail order tune.
BUILT LT1-11.34@125, 94 Z28 A4, 383 LT1, AFR 195 race readies/Comp 503 cam, 3.42's, 150 TNT Nitrous
Javier97Z28-11.37@118.9, 97 Z28 A4, 355, LE Heads/Cam, Yank PT4000, Moser 9", 4.11's
John Trevino (Greaseymec) 11.48@118 1.58 60' NA 383 LE2 292XFI, 9" 3.89, 3600 stall, 26" MT ET Streets
Jason Muchmore-11.5@119, 97 Camaro, 383, 100 shot, stall, 3.73's, stock suspension, drag radials.
Lloyd Elliott-11.541@117.4, 383, H/C, stall, 3.42, stock suspension, 3820lbs
John P. (1SlowFormula)-11.561@118.00, 95 Formula A4, Bolt-ons/NA/2835 lbs "Bolt on Record"
ZEX-Z-11.59@119, 94 Z28 Convertible A4, 4.10's, tune, Longtubes, 150 shot
Chris Jones-11.650@118.76, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/NA/3220lbs
IrocSS85 11.69 @114.23 on a 1.61 3:42 gears, 383, 3800 EDGE stall, 15" et streets
big dave-11.71@117.4, '94 Z28, Ported stock heads/846 cam/stock bottom end/~3700#
joelster 11.72@114.44, stock bottom end plus big cam, TFS heads, 5000 stall, N/A
Nick Merrifield-11.79@113.5, 94 Z28 A4, 383
Shon Herron-11.805@113.96, 97 Z28 M6, Bolt-ons/NA/3100lbs "Bolt on Record holder 3/26/06 - 09/21/08"
timelord-11.811@116.212 1.596 60ft - 396 LT1/4L60E N.A. 3640 lbs
Josh Laitner (96LT1355z28)-11.87@116 96 Z28, M6, ported heads, cam, 9", bolt ons, N/A, 3490 pounds
Mike Stevens-11.89/119mph 1997 m6 cam'd/100shot, bolt ons, 12 bolt, 1.90 60ft
James Montigny-11.892 @ 113.00mph, 93 Firehawk, LE2 Heads, LE1HL cam, SS4000, MT ETDRs. -103 DA Full street weight + 275lbs driver.
Colin91Z-11.90@118.4, N/A, 96 z28, 350ci, M6, 10 bolt, ~3500lbs with driver
camzaro28-11.9@115, 97 Z/28 A4, bolt ons +150 shot +2200 D.A.
ToxicFormula-11.913@113.89 stock internals LT1, full interior, MT Radial, 100 wet shot, bolt-ons, 3.73 gears, CPT race built 4l60E, 3200 stall, PCMforLess tune, Suspension.
Dwayne Jennings AKA 96capricemgr 11.935@ 112.83mph 96 Caprice, A4, Advanced Induction 190cc heads and cam, stock shortblock 4100lbs
Soccerbum21-11.938@110.87 Stock rebuilt LT1, 3663 raceweight, 120 shot MT ET Street DOT slicks (26x10.5x16), Auto 2.73's.
WhyHelloOfficer-12.06@116, 94 Z28, LT4 Hot Cam Kit,PI 3000 Stall, NX Wet 100 Shot, Bolt-ons, 3.23s, 3700lbs
Aaron Guerrette-12.086@113.00, 94 Z28, 383, Hotcam, Ported heads, stock valves, All bolt-ons, 2000 stall, 3.23, 3700lbs.
The LT1 That Could-12.241 @ 119.93, 2.087 60', 3150 DA - 95 Z28 A4, Pacesetter LTs, TDs w/ Bullets, 3.42s, TNT 150 Shot, Stock Internal/Suspension/Converter
Isaac C. (Street Demon2k3/NastyCamd93)- 12.26@110mph, 1.66, Built 355: LE2.2 cam, 4K RPM stall, 3.73, full bolt-on's
Mikey 97Z M6-12.39@114.27, 97 Z28 M6, NA/Bolt-ons/DIY Ported Heads/CC XE224-236/3470lbs
Smokedoutz28-12.3@113, 97 M6 Stock Bottom end, Stock heads, 847 cam, Bolt on's
buzz12586-12.32@114, 95 Z28 M6 355, CC503/Full bolt on/245-50-16 Nittos
97m6formula-12.4@122 97Formula, M6, Cam, headers, 100 shot, sprayed at the 1/8th
Bobby aka 'The Big Show'-12.40@115, 93 Z28 Complete Spohn Suspension, Ford 9", Strange Rear Brakes, Coan TH-400, 3000 stall, 385 ci, Dominion 32 Valve Heads, Custom Cam, Custom Single Plane Intake, Custom fuel system, 3400lbs
Tony Quadros (CamaroRacing12) - 12.495@107.32, 95 Z28 A4, Bolt-ons only/NA/3356lbs
RealQuick-12.5@114mph, 95 Z28, M6, H/C
Psycho_Teddy-12.572@104.27, 94 Z28, A4, 383(Forged Bottom End)/LT4 Hot Cam, Spohn Suspension
SHOCKER (blackz6sp)-11.72@115.83, 95 Z28, A4, Stock LT1, 3800stall, 150 shot
Old Oct 31, 2008 | 02:34 PM
  #65
updated
Old Nov 4, 2008 | 04:51 PM
  #66
LS1 SPEED's Avatar
add me to the list NA for now
Larry Hamilton 10.97 @ 121 SI 396 LT1, LE HR, SI LT1 heads/intake, 4L60E/SS4000, S60/3.73 3400ish race weight
Old Nov 5, 2008 | 07:32 PM
  #67
tomcowle's Avatar
tomcowle 11.481 at 118.98 mph, 1.502 sixty "BOLT-ON RECORD". 1995 Camaro Bolt-ons/Auto/Fuel Injected (11.502 with a carb).
What, I get no credit for my owning the record for the Summer of 2008??!! I see how you are...
Old Nov 5, 2008 | 11:46 PM
  #68
AChotrod's Avatar
me 13.32 @ 103 cat back DRs lil suspension
 Michael S. Palmer
Old Nov 5, 2008 | 11:47 PM
  #69
AChotrod's Avatar
oh and jakesz28 is in the mid to low 9s now
Old Nov 5, 2008 | 11:48 PM
  #70
AChotrod's Avatar
DAMN
Old Nov 8, 2008 | 10:25 PM
  #71
CamaroRacing12's Avatar
here we go again....
Old Nov 9, 2008 | 07:35 AM
  #72
tomcowle's Avatar
Yep
Old Nov 9, 2008 | 07:26 PM
  #73
LS1 SPEED's Avatar
can you add Speed Inc to the description
TIA
Old Nov 9, 2008 | 08:30 PM
  #74
yeah but what can you really say, he goes and backs up his stuff... Everyone complained when Tom had a carb setup to get faster then the record, so he stepped back to a stock manifold and EFI to get it, so I will be a man a relinquish the record to Tom, at least for now, then I will tell him to
LOL
Old Nov 9, 2008 | 08:32 PM
  #75
TIA
you already have SI in the description a few places, or were you asking for your screen name to be added?
Old Nov 9, 2008 | 08:41 PM
  #76
Larry would something like this be good?
Larry Hamilton (LS1 Speed)-10.97@121, Speed Inc.(SI) 396 LT1, LE HR, SI LT1 heads/intake, 4L60E/SS4000, S60/3.73, 3400#
Old Nov 9, 2008 | 11:20 PM
  #77
2XR95Z28's Avatar
Joe Newcomer- 13.08@102. 95 Z28. Stock Internals, 3200vig, Intake, Exhaust, Full weight.
Old Nov 10, 2008 | 12:50 PM
  #78
LS1 SPEED's Avatar
yes..that's cool. I'm not sure if people would know the SI.
thanks
Old Nov 10, 2008 | 07:50 PM
  #79
everything is updated...
BTW, we hit the limit of the character count in that first post, so now some of the slower guys will be getting knocked off and I will have to prune some of the vehicle details. So if you want to stay on the list make your cars faster, LOL...
Old Nov 10, 2008 | 08:19 PM
  #80
LS1 SPEED's Avatar
ha! thanks
