Whats making this noise?
my clutch was changed out with a stock spec around 25k miles ago it engages just fine and hasnt made any noise till like the last 3-400 miles or so. it's fairly noisy chattering sound any time i push in the clutch pedal i also got a heavy grinding noise any time i tried to get the car rolling from a stop. so i spent a good amount of time swapping out my throw out bearing which was completely mangled so i figured it would be the problem i dont get much of the grinding noise but i still get the chatter in my transmission. it's loud enough to notice over music playing with my windows up so im a bit concerned and if i dig into that trnasmission again i was a good idea of what i actually need to swap out. any ideas would be awesome. could it be my slave cylinder or my clutch disk off balance or something? Thanks alot
