Clutch fluid opinions
Ok searched a while and these are the top fluids Ive found to stop boiling. Im running DOT 4 right now and its boiling and blacker than satans heart. Im looking at these fluids and would like some feedback...
Castrol SRF
MotulRBF600
NEO super dot 610
Leaning toward the NEO super dot 610 because its boiling points are a little bit higher than the rbf600 and its alot cheaper than castrol SRF.
Thoughts? Where can I pick these up?
Castrol SRF
MotulRBF600
NEO super dot 610
I'm also curious, after 4 runs at the strip, my master cyl. resevoir was almost empty!!! I put some prestone dot 4 synthetic in to top it off (it says it is safe to mix with anything) and it hasn't dropped so far, but I haven't been back to the track yet, just normal driving.
