Clutch Problem (Spec stage 3 + 5.0shifter)
I got home from Texas yesterday, drove the whole way Clutch is a spec stage 3, 5.0 shifter.
Anyways on the drive home the shifting was perfect and was what I expected, but one point in the drive the pedal felt really loose and it wouldn't go into any gear, it would stall if I tried to push it into gear with the clutch still in. I noticed there was no fluid, so I got to a gas station and bought some dot 3 brake fluid and filled it up (crappy fluid?) So it was shifting good again, well I get home yesterday go to work then when I get off it was doing the same thing but this time the fluid was full still, I was stuck at the gate of my community for 10 minutes trying to get it into gear, I pumped the pedal for awhile incase there was air but no good.
It continues to do this.
The only way I can get it into gear is if I push the clutch really hard then slam it into a gear.
I don't know much about the clutch stuff, but maybe the fluid I added was just a shitty thing to do for the spec clutch as it was just some random **** from a gas station.
Any help is appreciated
Thanks
Thanks
change your sig. You liscence plate will be a little funny now, as it isn't a ws6.
Anyhow bleed the system- may look at the mityvac system as it may be a temporary fix. sounds like the slave is going out.
