Braided Clutch Line Gm V6 Only?
I was looking at the firewall where the clutch master cylinder comes out on my
2001 SS and the braided line that runs from it under the heat shield to the transmission has a yellow tag on it that says GM V6 Only. What does other
peoples say? Is there a difference? I know the previous owner had the clutch master changed at the dealer because of some kind of noise. The vehicle shifts fine just a little harder in the morning. You can see the tag on this picture from install university but not clear enough.
