Diamond Clutch Co !
Diamond Clutch Co !
Diamond Clutch is a somewhat new clutch offering. I started this clutch company over 1.5 years ago. It was designed to be very durable and still reasonably priced. The Stage 3 (most popular) is a full 12 inch cera-metallic disc very similar to the Text oz700. Rated at 700HP. It uses a 12 inch HD pressure plate. I offer 2 choices as far as the flywheel goes. 25lb billet steel or 16lb 4340 chromoly. After a lot of R&D it was discovered that chromoly is the only lightweight material that is durable enough to resist the heat. Just for comparison, the stock flywheel is 23lbs.
Warranty: 12month / 12k miles
At any rate, here are the prices.
Stage 3 clutch kit with your choice of 25lb or 16lb flywheel - $670
Add $80 for a new slave cylinder
Add $20 for a new pilot bearing and alignment tool
Or, if you need the disc and pressure plate only, $425
The Stage 2 kit comes complete with a stock flywheel, organic 12in disc, HD pressure plate, pilot bearing, alignment tool, and throwout bearing. Price $495
Add $50 for a new slave.
Stage 1 is just a stock LS6 clutch kit, includes the flywheel, disc, pressure plate, throwout bearing, pilot bearing, alignment tool. Price $345
We are in the process of working of the twin disc and triple disc clutch kits for Stage 4 and 5.
References: (Note: All the people are referrring to the Stage 3)
https://ls1tech.com/forums/texas-mem...ble-price.html
https://ls1tech.com/forums/texas-mem...-clutches.html
https://ls1tech.com/forums/texas-mem...rformance.html
https://ls1tech.com/forums/texas-mem...l-special.html
Contact Info:
Diamond Clutch
c/o Texas Drivetrain Performance
10011 Harmon Rd
Suite 155
Fort Worth, TX 76177
817-300-6840
txdrivetrain@hotmail.com
Contact Info:
Diamond Clutch
10011 Harmon Rd
Suite 155
817-300-6840
Specials!
For the next 2 months, I will be offering free shipping for any LS1Tech member on the Stage 2 or Stage 3 clutch kit! This only applies to the lower 48, btw
