Does YOUR Clutch Setup need a Shim?
#201
The tick shim plates are perfect if the shims needed are around ~.175" from what I recall. Basically when shims are added and you notice that your slave is no longer registering on the transmission front plate concentric ring, there could be benefit from this the type of spacer I posted
#202
- Measurement "A" is the distance between the surface of the bellhousing that meets the transmission to the tip of the pressure plate fingers. To get an accurate measurement, the clutch must be torqued properly.
- Measurement "B" is the distance between the throwout bearing surface to the transmission surface that meets the bellhousing. To get an accurate measurement, the slave spring must be removed and the bearing must be fully seated at the bottom of it's travel; resting on the slave's base.
If there is no difference between the two measurements, or if "B" is greater than "A", there could be a problem with clutch engagement which could result in premature clutch slip and eventually a total failure.
http://www.tickperformance.com/tick-...im-kit-3-pack/
"Your “A minus B” measurement should be 0.125 to 0.200 for adequate bearing travel and to allow for clutch wear."
So which is it? 1/16" to 1/8" or 1/8" to 1/5" ????
#204
Spec stage 2 clutch
I have installed the stage 2 clutch on my car, a 2007 Saturn ion 2.4. The clutch did not come with the spacers or the bolts that are being talked about. Can someone please tell me where I can get these parts? I am desperate for them a I have not been able to drive my car for 2 weeks. Thanks in advance
#207
#208
#210
#211
Hello all
I've been trying to install my clutch for proper disengagement on my 2002 C5 Z06. I am using a Monster LT1S clutch with a stock slave cylinder.
I have found that my "measurement A" is the same as "measurement B". Therefore I need the opposite of a shim:
A shorter TOB or slave assembly
or
A clutch assembly with lower clutch spring forks.
However neither of these seem possible without modifying my equipment.
Am I doing something wrong? I measured dimension B with the clutch bleeder open.
or
#212
so i have a Mcleod RXT. if i jack up the car, put it in first, and push the clutch to the floor, the wheels will spin. i have to be very careful shifting also, like 2nd or 4th i need to not slam it will grind. and downshifting i have to rev match. is that a tranny issue, a tick master adjustment issue, or a shim issue? i have the shim 3 pack and the tick master itself is installed.
#213
Moderator
Received 1,836 Likes
How high off the floor is your pedal? First thing I'd try is making your rid longer (giggeddy)
#216
Moderator
#217
On your webpage, you then state
#218
Moderator
#219
#220
Never bought an aftermarket clutch kit that needed a shim before. So is the plan supposed to be to buy a ~$800 clutch kit w/ flywheel and then buy the extra shims just incase it was not correctly built? Are stock LS1/T56 mating surfaces that large of a variance? If I am buying a new clutch, PP, Flywheel, Slave, I still need to buy a shim kit to make the new parts fit correctly? This is a stock Bottom, Stock Trans 2001 Camaro.
My apologies if this is common place on RWD setups, I have had transverse AWD and FWD setups till this car. Also been trying to solve the damn sticky pedal BS for last couple weekends. Just finished new MC and still cant get more than 3 gears out of it.
