Does YOUR Clutch Setup need a Shim?
Old 12-09-2008, 11:48 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Thumbs up Does YOUR Clutch Setup need a Shim?
I get a ton of PMs from guys asking if their clutch setups need to be shimmed and when I suggest measuring to be sure, their first response is usually "how?" To be as helpful as I can to everyone, I'm going to try and describe the measurement process. It's tough to do without pictures, but try and follow me here:
During your next clutch install, determine if your slave cylinder needs to be shimmed or not. To do so, you need to take two measurements:
  1. Measurement "A" is the distance between the surface of the bellhousing that meets the transmission to the tip of the pressure plate fingers. To get an accurate measurement, the clutch must be torqued properly.
  2. Measurement "B" is the distance between the throwout bearing surface to the transmission surface that meets the bellhousing. To get an accurate measurement, the slave spring must be removed and the bearing must be fully seated at the bottom of it's travel; resting on the slave's base.
Once you've got your two measurements, make sure that measurement "B" is ~1/16" to 1/8" LESS than measurement "A". If you come up with more than 1/8", add an appropriately sized shim between the slave and the transmission in order to get the measurements where they need to be.
If there is no difference between the two measurements, or if "B" is greater than "A", there could be a problem with clutch engagement which could result in premature clutch slip and eventually a total failure.
I'm proud to announce that Tick Performance is now making the use of shims even more precise by offering THREE difference thicknesses:Since there is no way to tell which shim you'll need before measuring, it's a smart idea to keep a few on hand prior to install so you're not held up in shipping if you need one. For this reason, we offer a discounted 3 Pack:
We're always in pursuit of new ways to get you guys shifting as quickly & efficiently as possible. Determining if your setup needs a shim or not is quick, easy and cheap way to ensure proper function and long life out of your next clutch.
Good luck guys!
Old 12-09-2008, 12:19 PM
SNLPerformance's Avatar
Joey, you guys rock!
Thanks for getting this info to customers, and, thanks for the consistent support of this community!
P.S. Monster Clutches do NOT need shims!
Old 12-09-2008, 03:36 PM
Grifter's Avatar
Thanks for the post Joey. I understand the "A" measurement, I can't visualize the "B" measurement though.
Old 12-09-2008, 04:01 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
Heres a pic, keep in mind the giant spring under the bearing is removed and the bearing is pushed as far toward the base of the slave as it will travel when actually taking your measurement:
Old 12-09-2008, 04:10 PM
Grifter's Avatar
Awesome, thanks a lot! So "A" is for the clutch and "B" is for the slave?
Old 12-09-2008, 04:19 PM
eseibel67's Avatar
No, the difference between "A" and "B" is the clearance required when the clutch is engaged.
Old 12-09-2008, 04:25 PM
LS1TECH Sponsor
Yeah, heres "A":
Old 12-09-2008, 04:43 PM
Restricted User
Lawnboy's Avatar
my spec stage 3+ didnt come with one , they forgot to put it in the box.
Old 12-09-2008, 06:53 PM
LS1Tech Sponsor
Slowhawk's Avatar
Good post.It is probly the #1 reason clutches prematurely wear out.
In my experiance it is needed to check on every single clutch setup.Atleast 60% of the SPEC's we do never need the shim and the burnt one's we've pulled had the shim when it wasn't needed.I like 1/8 -1/4" air gap to make room for clutch break in.
Old 12-09-2008, 07:13 PM
qwikz28's Avatar
my spec clutch just went because the installer did not shim it. i am willing to bet all the spec failures on this board are due to the same problem. good info guys! just want you to know i'm picking up my car tomorrow and will be the first time i drive my car with teh new Tick Master Cylinder
The following users liked this post:
oldngray (06-19-2020)
Old 12-09-2008, 07:14 PM
itsjustaSB's Avatar
thanks guys good info i always wondered how to tell cant belive i never put it toghter that its was that easy this is why i am always on this site you never stop learning
Old 12-09-2008, 07:46 PM
LS1TECH Sponsor
One other bit of info that should be added is something that Joey already made note of in the original post. The tob must be seated against the base of the slave when taking your measurement. Sometimes in order to do this, the bleader will need to be loosened. If the TOB won't seat even with the bleeder cracked, there could be a problem with the slave itself which could also cause clutch engagement issues and premature clutch failure. Basically you're just looking for a little gap, and Slowhawk is correct. As the clutch breaks in the gap will become a bit less and less. Too much gap however, and there will be dissengagement and shifting issues due to a dragging clutch.
Old 12-09-2008, 08:36 PM
2000_SS's Avatar
this is valuable info...sticky-worthy IMHO
Old 12-09-2008, 09:09 PM
Engine_HP's Avatar
so i can always find it when i need it
Old 12-09-2008, 09:20 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Def Sticky worthy
Old 12-09-2008, 11:02 PM
ABQ99TA's Avatar
Awesome info
Old 12-10-2008, 08:31 AM
on2
on2's Avatar
Anybody have experience with the Exedy Hypersingle?
Old 12-10-2008, 09:03 AM
Grifter's Avatar
I think you misunderstood my post. "A" is the measurement of the clutch, "B" is the measurement of the slave. With those numbers you find out what size shim, if any, is needed.
Definately make this a sticky.
Originally Posted by Jonathan@Tick
Yeah, heres "A":
Just what I thought!
Old 12-10-2008, 09:18 AM
tunedportcj5's Avatar
Awesome info guys - Thanks!
Here is some info from RAM's site on shimming. I have a dual disc I am about to install but I need to measure for the correct shim.
Where can we get a set of shims? I don't want to have the driveline all torn down and then have to order up some shims.. lol
http://www.ramclutches.com/Tech/Tech...%20Bearing.jpg
Old 12-10-2008, 09:31 AM
Can someone also explain why an adjustable Master is needed? And also explain the proper way of setting one up?
Quick Reply: Does YOUR Clutch Setup need a Shim?
