Trans. fluid rec. by 6 spd trans. builders?
What kind of lubricants are being ran in trans?
Race?
Street?
I saw some different fluids being used at lsx shootout in memphis. What is yours?
Race?
Street?
Tremec specifies that ATF is used, so thats what most people run.
Mobil 1 Synthetic ATF is highly reccommended by most rebuilders.
Some people run synchromesh, but blocker rings really aren't designed to work with that fluid, plus its thicker which can create shifting issues.
I saw two manual cars using what I thought was a lucas product in memphis it had a green look to it and would hardly come off the gear sets with brake clean it was caked onto the gears and the shafts inside almost like grease when the trans. was taken apart.
+1 for the dex 3. I had syncromesh in mine (got it used with the mesh in it, so I put it back in), then I drained it out and flushed it and put some dex 3 and it made a huge difference with cold shifting and shifting in general. Now it only grinds slightly in 5th when its really really cold, instead of into every gear.
I used DEX VI in my recent clutch install. I read it does better for some climates. It drives great, I just don't have the 500 hundred miles on the new Clutch. So I haven't tested a WOT in it.
