How to make T56 hold up in high HP cars.
#101
i decided to go ahead and do this since i i have the transmission out and im going to up those fitting mentioned earlier in the thread. do you tap the hole you drill? if so what is the thread and size used for the -8an fitting listed there?
#102
So does the integrated pump on the C6 move enough fluid to spray onto the gear set? I have have a C5 and would like to utilize this pump for this... if not enough pressure maybe I could put a 90° fitting at the top of the case so it would drain down on it? Space permitting of course...
#103
