Very hard to put car in Reverse
Old 10-20-2003, 01:56 PM
98Blubrd's Avatar
Default Very hard to put car in Reverse
The other day it became very hard to but it in reverse. Its like a very strong spring or something is trying to keep it out of reverse. I use my knee to help me push it over far enough. It goes in to reverse and doesnt pop out or anything. I am planning on rebuilding it myself within the next couple months but just wondering what happened. thanks for your help.
Old 10-20-2003, 02:16 PM
verbs's Avatar
Default Re: Very hard to put car in Reverse
Check your reverse lockout solenoid and make sure its plugged in
Old 10-20-2003, 04:51 PM
98Blubrd's Avatar
Where is it located? Also it is not locked out just hard to put it in. Like it has quite a bit of pressure on it.
Old 10-20-2003, 05:25 PM
verbs's Avatar
plugs into the tranny on the driver side
Old 10-20-2003, 07:01 PM
JRcamaroZ28's Avatar
Also check you ENG SEN (yellow 20A) fuse under the hood. if that blows out your lockout can be disabled along w/ dome other things.
JR
Old 10-20-2003, 07:06 PM
kp
kp's Avatar
Check the fuse first, the lockout solenoid is just left of where the shifter is mounted. It doesnt 'lock out' reverse 100% - just makes it real hard to get it over into the gate if it isnt working..
Old 10-20-2003, 11:04 PM
WU8
WU8's Avatar
This happened to mine tonight too, very hard to get it into reverse. It also threw on the SES light.
Old 10-21-2003, 12:06 AM
SSEUL8R's Avatar
sometimes air in the hydraulic system can cause this, mine was terrible to get in reverse before the new MC, and I bled the system. Probably not as easy of a fix as checking the lockout, but if that doesnt work you may need to bleed the system.
Old 10-21-2003, 08:12 AM
Viper's Avatar
Here's one for ya.
On a dyno session, my PCM was fried so they put in a PCM from an A4. Now I have the same problem as above. My guess is the computer is confused. I have SES P1810 and SES P0753. No blown fuses and the solenoid I'll check tonight ( although it was working fine prior to the swap ). I even disconnected the battery thinking the PCM was locking out the reverse, but it still happened with no battery. I'm getting my M6 PCM back this week, but I thought I'd share. FWIW.
Quick Reply: Very hard to put car in Reverse
