McLeod RST - balance? Is it true that I need to balance the RST twin with my flywheel before installing? Is this something that a lot of machine shops can even do? |
Originally Posted by N4cer
(Post 11508283)
Are C5 and LS1 F-body flywheels the same? |
yes sir |
Thanks buddy. That should solve an issue I have. |
We recommend balancing the flywheel,adapter ring & p/p bolted together as a assembly. Make sure to index the unit after it's balanced and then bolt up the unit to the back of the motor and lining up the index marks. |
I see. Guess I can leave the discs out. |
(Post 11508931)
© 2024 MH Sub I, LLC dba Internet Brands
