GOT MY NEW TRANY TR6060 (T56 Magnum)
I understand the curiosity over a new tranny option but I'd like to see after install & some abuse if it is really worth it over a tried, tested & proven properly built T56.
I just did a LS1 T56 with upgraded billet keys, bronze fork pads, iron 3-4 shift fork, machined Viper input shaft and Viper output shaft for a local customer. The bill came in at just under $2100 (core was provided) and I would put it against any TR6060/T56 Magnum out there.
I'm not saying the T56 Magnum is junk but its not much superior to the T56 IMO. If you need a unit and do not have a core, its a good option to consider. If you have a good core to work with, having it rebuilt is a better choice IMO.
and your right how many have taking 450. or how many 1000 horse vipers are there. good call, but if the t-56 is rated to 400 and hold 1000. then the magnum rated at 700 should hold like 1800.
only time will tell. but honestly, open one up. weither it is a magnum or a stock tr6060 out of a vete or stang. but gears are bigger and hold more. not to say that all the little thing arent upgraded.
The TR6060 gears are slightly wider than the T56 gears. This does increase the surface area of the contact pattern the gears make. How much does this really help? Only time will show.........
Personally, I would expect to see failure of the TR6060 right around the same power level as the Viper spec T56. All I can say is good luck if something does go down in the unit. I would imagine that the parts are going to be super expensive if even available through Tremec for the first couple of years.
And thats what could be the determining factor of weather it's a worthwhile swap or not VS a built T56. If it fits correctly & proves to be damn near impossible to break it'll be worth it especially after a couple years & upgrade parts hitting the market. But as of right now if your T56 breaks it's not a problem finding parts. Same can't be said for this new tranny option, yet anyway. And I could see that in itself sway peoples decision to try it out.
And yet LMR hired this homo and people take their cars there for T56 rebuilds and to get their cars tuned as if nothing ever happend.......
Hopefully D&D gets your order squared away and you get the right unit. Keep us posted on how much bs it takes to get it to fit in your car.
hahahah..... You guys are to much.
I was wondering if "The Magnum" is equipped with billet keys for all the sliders and bronze fork pads for all the forks ?
Also wondering about the syncros being superior to the double triple
syncros in the MN12 trannys ?
Also some tranny parts I buy from various vendors say made in the USA on the boxes. Others say Hencho en Mexico.
Anyone driven a new 2010 6 speed Camaro yet ?
It would be fun to dissect before sending it back ... j/k
I know a guy on Corral was converting a Viper TR6060 into his Mustang and issues finding a yoke to fit it. I wonder if the T56 Magnum uses the same yoke. If so, good f'n luck getting one. Hopefully it uses the same yoke a Ford 31 spline like the TKO series 5 speed.
It does not have bronze fork pads. The rings in the original TR6060 had powdered brass rings like the ones found in the TR3650 5 speed 1-2 rings. I have heard Tremec was redesigning the rings so I am not sure what the magnum has in it. The Tremec parts are made in Mexico as far as I know.
I don't know much about the TR3650 other than they come in the mustangs and the earlier GT's. ( meaning the latest mustang platform )
I read a few complaints regarding notchy shifts on the TR3650.
Eventhough the T56 Magnum trans is now available, that would suck if you couldn't get a yoke or had to pay out the nose for it ? On the flipside if the Magnum uses the TKO yoke that would make life easier. I hope GM used the same TKO 31 spline similar to the 2008+ C6 Vettes. hmmmm ?
The yoke for the yiper is just a thick-wall truck yoke nothing exotic. The Magnum uses a simple 31T yoke that has been in a Mustang for 10 years.Not too hard to find.
I have seen the inside of a magnum:
The Magnum has sintered bronze blocker material NOT powdered metal. They are trippl/ double cone but much larger than the M12 parts. The outer cones are steel not powdered metal.There are no billet struts because the struts are redesigned and don't use the stamped steel parts like the T56. Billit struts are no longer needed nor would they fit. As far as fork pads go- no brass but an upgrade material pad is available( Viper uses them). The gears are wider and the bearings are also much bigger. This is an obvious upgraded box.
#32
But there was never an issue with the size of the bearings in the T56 to begin with so larger is not really better. The TR6060 from the Viper uses its own special yoke and is only servicable with the driveshaft right now from Dodge. I tried to help a guy find one through Dana/Spicer and it was a no go. As long as the T56 magnum uses a standard 31 spline yoke, all is good as far as that goes. We have not seen the magnum yet so I cannot comment on it internally or externally except for pictures I have seen.
#33
When the torque rating goes up I would think the bearing choice would change, as it did. Perhaps you were lucky & never saw bearing problems. It is good that the TR6060 addresses this up front. Yes , It is a plus. The new Viper yoke is common & available. It is the same as the Ram SRT10 part # 05134234AB.
#35
I read the thread from Corral Forums.
Bikewiz had to end up buying a complete SRT10 driveshaft.
Those TR6060 viper transmissions are neat looking on the inside. ( At least I think so ). lol
The 1/2 and 3/4 shift forks are different than the T-56.
The plastic shoes/pads orange in color.
The syncros are really different.
That thread was an interesting read and observation.
#36
Did you notice they went back to using an aluminum 3-4 shift fork? I was told the T56 Magnum was suppose to have revised syncros in it. I guess the bronze rings are not working all that great.
#37
^^^ yes it has revised syncors. that is why the magnum was released in feb. then had a recall two days later. the stuff on the inside of the magnum is different then the tr6060. i know that sounds weird but it is true. they changed a few things. and dont questo me but i beileve D&D told me the new shift fork is carbon. or carbon fiber. or somthing like that.
#39
If they end up not using bronze, I wonder what other material they will go to.
Either way I would think the forks would be lighter.
Does the 2010 Camaro have a mutated TR6060 or the " Magnum " ?
If Tremec is redesigning the TR6060 into the Magnum... that would lead one to believe the earlier 2010 Camaro's trannies might be different than the later 2010 Camaros ???
Big_Bird I'm also now wondering, if your Magnum is the latest design.
Also I can understand why you would like the 2.66 tranny. I actually like the gear ratios better in my original 2000 T-56 as opposed to my
MN12 2.96.
